Leave A Message
发表于:昨天 11:55|本帖共 2,844 字 2851
       Product Description
  Product Name: 2044605424 Power Steering High Pressure Hose For Mercedes Benz C Class W204
  2044605424 is a high-performance power steering high-pressure hose tailored for Mercedes-Benz W204 C-Class. As a professional manufacturer of automotive steering system pipeline parts, we adopt standardized, refined and automated manufacturing processes for this product. Strict full-process production control effectively solves common aftermarket problems such as oil leakage, pipe bulging and aging failure, providing OE-quality replacement parts for global auto repair and wholesale markets.
  Product Specification Table
    Item Content OE Number 2044605424 Cross Reference OE A2044605424 Product Name Power Steering High Pressure Hose / Steering Oil Pipe Assembly Applicable Brand Mercedes-Benz Fitment Model Mercedes-Benz C-Class W204 Applicable Year 2007–2014 Engine Model 1.6L, 1.8L, 2.0L, 2.5L, 3.0L Gasoline Engine Power Output 129HP – 245HP Overall Length 680 mm Installation Position Power steering system, high-pressure pipeline between steering pump and steering gear Material Oil & high-pressure resistant synthetic rubber + multi-layer high-tensile steel wire braided layer + anti-rust precision aluminum alloy fittings Working Medium Automotive power steering fluid Working Pressure Sustained high pressure resistance for vehicle steering system Product Features Zero oil leakage, anti-aging, burst-proof, deformation-resistant, high temperature resistant, precise OE direct fit Quality Standard ISO/TS16949 Certified, OE equivalent aftermarket replacement part Warranty 24 Months MOQ 50 PCS Packaging Neutral export carton, private label and customized packaging available Lead Time 10–15 days for stock orders; 25–30 days for mass production
  Manufacturing Process
  Product Showcase
  Why Partner With Us?
  A: Each step of our production process have the quality checking workers. They will check the products one by one before going to next production step. And before package, our QC workers will choose 15% of the cargo to check the quality again to make sure the cargo is with good quality. If the 15% products have around 1% with defects, we will recheck all pieces of the cargo. And our quality warranty is 2 years. If any quality issues feedback from our customers, we will fully take charge of it.
  2. Q: How long is your delivery term?
  A: Our standard product delivery term is normally 30 days.A new product development is 60days including the mass production. Under normal circumstances there are standing stock for regular types.You can us to learn more details.
  3. Q: How many years is your company in auto parts business field?
  A: Our Company started since 2005,there is about 19 years history forus in auto parts business field.
  4. Q:Are you trading company or factory?
  A: We are factory with trading company.
  5. Q:What's the MOQ for each item?
  A: Our business way is spot sales,if the items we have stock,there is no limitation for MOQ to be manufactured based on your order.
  Product FAQs:
  1. Q: Do you manufacture both high-pressure and return hoses?
  A: Yes. We produce high-pressure hoses, return hoses, and complete steering hose assemblies.
  2. Q: Are all hoses pressure tested?
  A: Yes. Every hose is pressure tested before shipment to ensure safety and leak-free performance.
  Our Factory
  Certification
