Slash Knot Method Of Canvas Shoes
发表于:3 天前|本帖共 434 字 1076
       After passing through the first hole, tie a single knot inside, and the other end passes through the third hole on the left from the inside to the outside;
  Pass the shoelace through the second hole on the right;
  Finish the slash knot with blue shoelaces;
  Tie a diagonal knot with white shoelaces in the opposite direction;
  The method is the same as the blue shoelace method;
  The blue and white shoelaces finally come out from the hole in the tongue part;
  The way it comes out of the tongue;
  It's better to tie it loosely.
