Vatac Control Valves
发表于:2026-11-8 11:06:26|本帖共 3,439 字 280
       W
hat is a Control Valve?
  Control Valves, also know as Regulating Valves, consists of two main components: the valve body assembly and the actuator assembly (or actuator system), divided into four series: single seat control valve, double-seat control valve, sleeve control valve and self-operated control valve. Variants of the four types of valves can result in a number of different applicable structures, each having its particular application, features, advantages and disadvantages. Although some control valves have a wider range of applications than other valves, the control valves are not suitable for all operating conditions to jointly create the best solution for enhanced performance and reduced cost.
  Why Control Valves used?
  Control valve used in the field of industrial automation process control, it can change the final control elecments of the process parameters such as medium flow, pressure, temperature, liquid level by receiving the control signals from the control unit. The regulating valve is suitable for air, water, steam, various corrosive media, mud, oil, and other media.
  The most common final control element in the process control industries is the control valve. The control valve manipulates a flowing fluid, such as gas, steam, water, or chemical compounds, to compensate for the load disturbance and keep the regulated process variable as close as possible to the desired set point.
  Control valves may be the most important, but sometimes the most neglected, part of a control loop. The reason is usually the instrument engineer's unfamiliarity with the many facets, terminologies, and areas of engineering disciplines such as fluid mechanics, metallurgy, noise control, and piping and vessel design that can be involved depending on the severity of service conditions.
  Any control loop usually consists of a sensor of the process condition, a transmitter and a controller that compares the "process variable" received from the transmitter with the "set point," i.e., the desired process condition. The controller, in turn, sends a corrective signal to the "final control element," the last part of the loop and the "muscle" of the process control system. While the sensors of the process variables are the eyes, the controller the brain, then the final control element is the hands of the control loop. This makes it the most important, alas sometimes the least understood, part of an automatic control system. This comes about, in part, due to our strong attachment to electronic systems and computers causing some neglect in the proper understanding and proper use of the all important hardware.
  Importance of control valve selection
  The control valve is an actuator in the automatic control system, and its application quality directly reflects the adjustment quality of the system. As a terminal component in process control, people are more aware of its importance than in the past. The application of the regulating valve is very important, in addition to the quality of the product itself, whether the user is correctly installed, used, and maintained, it is very important to calculate and select correctly. Due to errors in calculation and selection, the system is opened and stopped, and some even cannot be used. Therefore, users and system designers should recognize the importance of the valve at the site, and must pay sufficient attention to the selection of the regulating valve.
  Principle of control valve selection
  1. Select the appropriate structural form and material according to the process conditions.
  2. Select the flow characteristics of the control valve according to the characteristics of the process object.
  3. Select the appropriate control valve diameter size based on the process operating parameters.
  4. Select the required auxiliary device according to the requirements of the process.
  5. Reasonably choose the executing agency. The response speed of the actuator should be sufficient to meet the process.
