What is the manufacturing technology of satellite printing machines?
发表于:2026-11-1 12:32:50|本帖共 982 字 3293
       The manufacturing technology of satellite soft version printing equipment, the printing version adopted by the soft version of the print is composed of a harder resin version and highly elastic photosensitive material. Light pressure printing is used during the printing process, so it is called soft version printing. Essence
  Compared with other printing methods, soft version printing has obvious advantages such as simple equipment structure, short production cycle, high production efficiency, and wide range of printing materials. In particular, water -based inks are used in printing, which meets the current increasing green environmental protection requirements.
  Satellite printing machine refers to a circular roller in the middle, and the four -color group printing machines are surrounded by four -color groups, just like surrounded by satellites, so it is called a satellite printing machine. Its tension is stable, the structure is simple, and the performance is very stable. Generally, rotating, wide printing.
  There are actually many satellite -style soft printing advantages, except for the advantages of high accuracy and fast speed.
内容质量很高。
8 小时前|本帖共 7 字 回复
