Introduce the lifting method and application fields of IBC lifting mixer
发表于:2026-10-20 14:08:12|本帖共 2,552 字 1702
  IBC lifting mixer is a mixing equipment that adapts to different barrels or liquid levels through a lifting mechanism. The lifting methods are divided into electric lifting and hydraulic lifting. The height of the mixer can be freely adjusted through hydraulic or electric lifting mechanisms, which helps reduce labor intensity, achieve fast positioning, and adapt to different liquid levels or container sizes. The operation is time-saving and labor-saving, without the need for manual lifting.
  IBC lifting agitator is suitable for liquid-liquid mixing, solid-liquid mixing and high viscosity material mixing in chemical industry, food and beverage, environmental protection and water treatment, other industries, such as paint, ink, resin, glue, glucose, honey, syrup, diluted concentrate, essence flavoring and other different liquids, and can also handle liquids with viscosity up to 20000 cp.
  The whole machine supports all-round non-standard customization, and can adjust the motor power, lifting and lowering stroke, mixing blade structure and material as needed (multiple blade types such as single blade, three blade, folding blade, etc. are available), to fit the actual production conditions of customers on site. Complete the mixing of ton bucket materials on site, without the need for repeated tank transfer and material pouring, greatly simplifying the entire production process, reducing material transfer losses, and reducing labor input for manual transfer and bucket replacement operations, effectively reducing the overall production cost of the enterprise.
  This machine adopts an electric mixing and hydraulic lifting structure, with one click adjustment of the mixing shaft lifting and lowering, which can be operated by a single person; The bottom of the relocation rack is designed with movable universal brake wheels, allowing the equipment to move flexibly. One device can be used for multiple ton drums to circulate, improving equipment utilization. The mixing shaft, mixing blade and other components in contact with the material are made of 304/316L stainless steel, which is corrosion-resistant and easy to clean; Equipped with foldable propeller blades, the blades can be retracted and pass through the narrow opening of IBC. After high-speed rotation, the blades are fully unfolded, and there are no dead corners in the mixing of the bucket, effectively preventing material settling and layering.
  The IBC mixer is equipped with a variable frequency speed control system, which can flexibly adjust the speed range and accurately match the mixing conditions according to different material viscosities. For high viscosity pastes and thick slurries, low-speed mixing is selected to avoid material splashing and excessive blade load; For low viscosity liquids and thinners, high-speed stirring is used to quickly disperse precipitates and achieve uniform mixing. The speed can be freely adjusted throughout the process, and the stirring rhythm is more controllable.
