Working principle of activated carbon filter element
发表于:2026-10-19 08:08:48|本帖共 1,576 字 4384
       Activated carbon filter element is a high-efficiency adsorption material, which is widely used in air purification, water treatment and other fields. Its core working principle is based on the dual effects of physical adsorption and chemical adsorption, which can effectively remove odors, organic matter, chlorine and other harmful substances.
  The adsorption capacity of activated carbon mainly depends on its unique porous structure. The micropore surface area of ​​each gram of activated carbon can reach 500~1500 square meters. These micropores are like countless "small traps" that can capture and lock impurity molecules in gas or liquid. When air or water flows through the activated carbon filter element, the pollutant molecules are adsorbed by the micropores, thereby purifying the medium.
  In addition, the surface chemical properties of activated carbon also enhance its adsorption effect. Through activation treatment (such as high-temperature steam or chemical activation), rich functional groups will be formed on the surface of activated carbon, so that it can not only adsorb non-polar substances (such as benzene and formaldehyde), but also react with some polar compounds (such as chlorine and hydrogen sulfide), further improving the purification efficiency.
  The life of the activated carbon filter element depends on the adsorption saturation. Once the micropores are filled, the adsorption capacity will decrease. Therefore, regular replacement or regeneration (such as exposure to sunlight, high temperature treatment) is the key to maintaining its performance. In the future, with the development of modified activated carbon technology, the adsorption selectivity and service life of the filter element will be further improved, providing more reliable protection for environmental protection and health.
