露点压力换算表
发表于:2026-10-16 13:19:41|本帖共 1,499 字 221
       压力霜点(露点)——压力——常压霜点(露点)对应的关系表(估算值) 压力 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.45 0.50 0.55 0.60 0.65 0.70 0.75 0.80 0.85 0.90 0.95 1.00 (MPa) (MPa) (MPa) (MPa) (MPa) (MPa) (MPa) (MPa) (MPa) (MPa) 压力霜点(0C) -26.0 -32.7 -34.8 -36.4 -37.8 -39.0 -40.1 -41.0 -41.8 -42.6 -49.3 -43.9 -44.5 -45.1 -45.5 -46.1 -46.5 -46.9 -47.3 -47.7 -26.5 -27.0 -33.6 -35.7 -37.4 -38.8 -39.9 -41.0 -41.9 -42.7 -43.4 -44.2 -44.8 -45.3 -45.9 -46.4 -46.9 -47.3 -47.8 -48.2 -48.5 -27.5 -28.0 -34.6 -36.6 -38.3 -39.7 -40.8 -41.9 -42.8 -43.6 -44.4 -45.0 -45.7 -46.2 -46.8 -47.4 -47.8 -48.2 -48.6 -49.0 -49.4 -28.5 -29.0 -35.6 -37.6 -39.2 -40.6 -41.7 -42.8 -43.6 -44.5 -45.2 -45.9 -46.5 -47.1 -47.6 -48.1 -48.6 -49.0 -49.4 -49.8 -50.2 -29.5 -30.0 -36.5 -38.5 -40.1 -41.5 -42.6 -43.6 -44.5 -45.3 -46.1 -46.8 -47.4 -48.0 -48.5 -49.0 -49.4 -49.9 -50.3 -50.7 -51.1 -30.5 -31.0 -37.4 -39.4 -41.0 -42.4 -43.5 -44.5 -45.4 -46.2 -46.9 -47.6 -48.2 -48.8 -49.3 -49.8 -50.3 -50.7 -51.1 -51.5 -51.9 -31.5 -32.0 -38.4 -40.3 -42.0 -43.3 -44.4 -45.4 -45.7 -47.1 -47.8 -48.5 -49.1 -49.6 -50.2 -50.7 -51.1 -51.6 -52.1 -52.4 -52.7 -32.5 -33.0 -39.3 -41.3 -42.9 -44.2 -45.3 -46.3 -47.2 -48.0 -48.7 -49.4 -50.0 -50.5 -51.0 -51.5 -51.9 -52.4 -52.8 -53.2 -53.5 -33.5 -34.0 -40.3 -42.2 -43.8 -45.1 -46.2 -47.2 -48.1 -48.8 -49.6 -50.2 -50.8 -51.4 -51.8 -52.3 -52.8 -53.2 -53.6 -54.0 -54.4 -34.5 -35.0 -41.2 -49.2 -44.7 -46.0 -47.2 -48.1 -49.0 -49.7 -50.4 -51.1 -51.7 -52.2 -52.8 -53.2 -53.7 -54.1 -54.5 -54.9 -55.2 -35.5 -36.0 -43.0 -44.1 -45.7 -46.9 -48.0 -49.0 -49.9 -50.6 -51.3 -52.0 -52.5 -53.1 -53.6 -54.1 -54.3 -54.9 -55.4 -55.7 -56.1 -36.5 -37.0 -43.2 -45.0 -46.6 -47.8 -49.0 -49.9 -50.8 -51.5 -52.2 -52.8 -53.4 -53.9 -54.4 -54.9 -55.3 -55.8 -56.2 -56.6 -56.9 -37.5 注明:1)*列中的压力霜点即为低温露点仪的读数。根据露点有关理论,当露点温度小于零度时,称之为霜点。 <span style="
