👉This pelletizing line has been comprehensively upgraded, from
structural design to material selection-designed for high-quality
recycled pellets.
1️⃣ Two-Stage Extrusion System - Dual Filtration for Purer
Particles
The entire line utilizes a two-stage extrusion system, meaning two
extruders operate in series, each equipped with an independent screen
changer.
✔ Dual Melting
✔ Dual Filtration
✔ More Thorough Impurity Removal
🔹Especially suitable for recycled materials containing high levels of
impurities, such as films, printed films, and woven bags.
👉 Cleaner Finished Particles
👉 Fewer Black Spots
👉 More Stable Melting
👉 Significantly Improved Particle Quality
The first-stage extruder is equipped with a vacuum exhaust system
to effectively remove:
✔ Water vapor
✔ Ink volatiles
✔ Low-molecular-weight gases
🔹Especially suitable for:
Plastics containing moisture
Printable film materials
Materials containing a small amount of residual moisture after cleaning
The extruder barrel and screw are made of:
High-strength nitrided steel (38CrMoAlA)
Features:
✔ Excellent wear resistance
✔ Good corrosion resistance
✔ Strong high-temperature stability
This means:
👉 Longer service life
👉 Stable long-term operation
👉 Reduced maintenance costs
Truly suitable for continuous industrial production.
The compaction silo is equipped with a dust removal system
at the top, which effectively:
✔ Reduce dust
✔ Reduce impurities entering
✔ Improve the working environment
Also improve feeding stability, resulting in more uniform melting.
The cooling tank is equipped with a heat exchanger at the
bottom and connects to an independent chiller system.
This forms a circulating cooling system:
✔ Rapidly reduces water temperature
✔ Prevents overheating during long-term operation
✔ Maintains stable cooling effect
Advantages include:
👉 More thorough granule cooling
👉 No deformation
👉 No sticking
👉 Improved granule surface quality
Especially crucial for high-volume continuous production.
High-efficiency vibrating screens are used for:
✔ Removing fine powder
✔ Separating defective particles
✔ Improving uniformity
Ensuring final particles are:
👉 Clean
👉 Dry
👉 Consistent particle size
If you wish to:
👉 Improve pellet quality
👉 Reduce after-sales issues
👉 Increase profit margins
This Polish-configured pelletizing line is a more stable option.
📩 Welcome to inquire; customized production capacity
and configuration solutions are available.
