What are the indicators for water quality monitoring
发表于:2026-10-12 10:51:11|本帖共 3,276 字 1467
       Water quality monitoring is the process of monitoring and measuring the types of pollutants in the water, the concentration and changing trends of various pollutants, and the evaluation of water quality. The main monitoring items of water quality monitoring can be divided into two categories: the first category is a comprehensive indicator reflecting the water quality, such as temperature, color, turbidity, pH, conductivity, suspended matter and dissolved oxygen, chemical oxygen demand and biological oxygen demand The other is some toxic substances, such as phenol, cyanide, arsenic, lead, chromium, cadmium, mercury and organic pesticides.
  Common indicators for water quality testing include high-range COD, low-range COD, ammonia nitrogen, total phosphorus, total nitrogen, turbidity, chroma, nitrate nitrogen, nitrite nitrogen, hexavalent chromium, residual chlorine, total chlorine, chlorine dioxide, sulfuric acid Salt, phosphate, sulfide, fluoride, barium, total more than 20 indicators, etc.
  The following is an example to explain the meaning of these indicators:
  1. Chroma: If the chroma of drinking water is greater than 15 degrees, most people will feel disgusted. The standard stipulates that the color of drinking water should not exceed 15 degrees.
  2. Residual chlorine: Residual chlorine refers to the amount of chlorine remaining in the water after chlorination and disinfection of water after a certain period of contact. It has the ability of continuous sterilization in the water, which can prevent the pollution of the water supply pipeline itself and ensure the quality of the water supply.
  3. Chemical oxygen demand: refers to the amount of oxygen required by chemical oxidants to oxidize organic pollutants in water. The higher the chemical oxygen consumption, the more organic pollutants in the water. The organic pollutants in the water mainly come from the discharge of domestic sewage and industrial wastewater, and the decomposed animals and plants flow into the water body.
  4. Turbidity: It is the expression language of the optical properties of water samples. It is used to express the clarity and turbidity of water. It is one of the most important indicators for measuring the goodness of water quality. It is also used to evaluate the purification efficiency of water treatment equipment and evaluate the state of water treatment technology. Important reference. The reduction of turbidity means that the content of microorganisms, bacteria, viruses and other microorganisms in the water body is reduced, which not only improves the disinfection and sterilization effect, but also helps reduce the amount of halogenated organic matter produced.
  5. Odor: Water odor is mainly caused by the presence of organic matter, which may be a manifestation of increased biological activity and industrial pollution. Changes in the normal odor of public water supply may be a signal of changes in raw water quality and insufficient water treatment.
  6. The total number of bacteria: The bacteria in the water come from the air, soil, sewage, garbage and dead animals and plants. There are many types of bacteria in the water, including pathogenic bacteria. China stipulates that the standard of drinking water is that the total number of bacteria in 1 ml of water does not exceed 100.
  7. Escherichia coli: coliform bacteria (e). Coli is a representative bacteria of the Escherichia genus (Escherichia). Generally, it does not get sick. It is a resident bacteria in the intestines of humans and animals. Under certain conditions, it can cause extra-intestinal infections. Some serotype strains are highly pathogenic and cause diarrhea, collectively referred to as pathogenic Escherichia coli. Intestinal bacilli are a group of G-bacilli with similar biological characteristics, which mostly reside in the intestines of humans and animals.
