Mechanical manufacturing is one of the major projects in industry, just like the skeleton structure of manufacturing. The model requirements we need are all manufactured according to the requirements through the existing equipment. Mechanical processing is here, and is responsible for slowly making what is needed. Processing is a step-by-step modification until the modification is what we need. It's like a piece of raw material. We use a knife to modify it. We let the knife cut off the excess parts, and we will add it if there is not enough. Processing is such a principle. Mechanical processing is not just a simple addition and reduction, we need a variety of shapes, our processing will become more diverse, we need a variety of equipment to reasonably process what we want. Every piece of equipment processing is like a knife, and it is also responsible for adding. Because the processed parts are the parts we need, so the processing of mechanical parts is like reprocessing in mechanical processing. Because the part is a high-precision item, we must control the precision of the part to make it qualified. The processing of parts is not like simple addition or subtraction, and it feels more like fine sculpting. We use more elaborate means to control the data of every detail, so as to be as close as possible to the needs. The accuracy of parts is an important indicator. The purpose of our parts processing is to make detailed modifications to the processed parts. If mechanical processing is a knife, then mechanical parts are processed like needles. We first mold them with processing, and then use small processing methods to reduce the error of the parts and become in line with our required data.
