Voltage transformers can be divided into two types based on their working principles: electromagnetic induction principle (referred to as electromagnetic type) and capacitive voltage divider principle (referred to as capacitive type). Voltage transformers can be divided into dry type, plastic cast type, oil immersed type, inflatable type, insulator type, etc. according to their insulation structure. In recent years, plastic casting voltage transformers have been widely used, and the change from oil immersed forest open type to closed type has also reduced faults. 1. Plastic cast voltage transformer. It is divided into two types: semi pouring and full pouring. Half pouring method is to pour first and then install the iron core; Full casting is the process of casting the winding and iron core together after installation. The wire is made of high-strength enameled wire, and the insulation between layers and windings is made of cable paper or composite insulation paper. The insulation between primary and secondary windings is made of epoxy resin cylinder, and the insulation to ground is made of epoxy resin. 2. Oil immersed voltage transformer. Divided into voltage transformers of 35kV and above 66kV. A 35kV voltage transformer is similar to a small oil immersed transformer; Voltage transformers of 66kV and above adopt a porcelain box structure. 3. Capacitive voltage transformers not only serve as electromagnetic voltage transformers, but also serve as high-frequency carriers for coupling capacitors. They are generally used for voltage levels of 220kV and above. 4. SF6 gas insulated voltage transformer. This is a new type of voltage transformer that uses SF6 gas as the main insulation. Its insulation performance is stable, without fire hazards, oil-free, pollution-free, and easy to maintain.
