恒温密闭超声波反应器中英文介绍
发表于:2026-10-4 10:12:27|本帖共 1,753 字 844
       恒温密闭超声波反应器用于声化学反应、酶促反应、纳米材料的制备。被广泛应用于化学化工、环境工程、生物化学、微生物学、药物化学、物理学、动物学等领域。反应器可连接回流冷凝器、加料滴液漏斗、导入气体鼓泡器、真空排气管等各种化学合成装置配件,化学合成反应装置套件、微量有机合成套件可选。 超声脉冲激发装置独立开关,脉冲激发时间可调,脉冲次数自动计数控制。本仪器还解决了变幅杆与反应器密封的难题,再配以各种化学反应器的附件,足以能够实现反应体系气氛的隔离和汽相的冷凝回流。控温全封闭多频段超声反应器的结构形式亦适于进一步构建多种新型反应器。 恒温密闭超声波反应器优势 1.全密闭结构,可通入多种气体参与反应; 2.超声波反应器的超声变幅杆浸入式,处理效果好; 3.超声功率连续可调,大功率50-1000W可调节; 4.超声波反应器的超声脉冲激发装置独立开关,脉冲激发时间可调,脉冲次数自动计数控制; 5.超声波换能器与液体接触部分可选用钛金属,耐腐蚀。 Constant temperature airtight ultrasonic reactor used in sonochemical reaction, enzymatic reaction, the preparation of nanometer materials. Is widely used in chemical, environmental engineering, biochemistry, microbiology, drug chemistry, physics, zoology, etc. Reactor can be connected reflux condenser, charging dropping funnel, import gas bubbler, vacuum exhaust pipe and other chemical equipment accessories, chemical synthesis reaction device suite, suite of trace organic synthesis is optional. Ultrasonic pulse excitation device independent switch, adjustable pulse excitation time, pulse frequency automatic counting control. The instrument has solved the difficult problem of the amplitude and the reactor sealed, combined with a variety of chemical reactor attachments, enough to achieve isolation and vapor phase reaction system atmosphere condenser. The structure of temperature control is fully enclosed multiband ultrasonic reactor is also suitable for further build a variety of new type reactor. Ultrasonic reactor 1. The fully closed structure and can pass into the various gases in response; 2. The ultrasonic immersion, the amplitude of ultrasonic reactor treatment effect is good; 3. Continuous adjustable ultrasonic power, the maximum power of 50-1000 w adjustable; 4. Ultrasonic reactor ultrasonic pulse excitation device independent switch, adjustable pulse excitation time, pulse frequency automatic counting control; 5. Contact with the liquid part of the ultrasonic transducer can choose titanium, corrosion resistance.
