Product DescriptionProduct NameWheel hub assembly VKBA3931BrandPPB/Neutral Or As Your RequestFeaturesLow friction, Long service life, Enhanced operational reliability, Consistency of roller profiles and sizes, Rigid bearing application, Running-in period with reduced temperature peaks, Separable and interchangeable With low and smoothly coefficient of frictionQuality standardISO9001, TS16949Quality Control Process1. Assembly2. Windage test 3. Cleaning4. Rotary test5. Greasing and gland6. Noise inspection7. Appearance inspection8. Rust prevention9. Product packagingServiceOEM/ODM or customer logo acceptableTransmission System Front Axle Wheel Hub Bearing 713606360 for ALFA ROMEO 159Wheel Hub Unit Details Rim Hole Number: 4Flange Ø: 135 mmSupplementary Article/Info 2: with integrated ABS sensorOEM NUMBERTOYOTA: 42450-0D010TOYOTA: 42450-0D030TOYOTA: 42450-52020TOYOTA: 42450-52021 REFERENCE NUMBER200460ADT38332713 6186 80J4712058WBH-9012J4712058982195QWB135369511401764532764532VKBA 3931R169.5127508
Car ApplicationVehicleConstruction type Active yearsServiceEngine Code TOYOTA IST (NCP6_) 1.3 VVTi (NCP60)Hatchback 2004 - 200786 / 632NZ-FE TOYOTA PLATZ (NCP1_, SCP1_) 1.0 (SCP11_)Saloon 1999 - 200568 / 501SZ-FE TOYOTA VIOS / SOLUNA VIOS (_P4_) 1.5 (AXP42_, NCP42_)Saloon 2002 - 200892 / 685A-FE TOYOTA VIOS / SOLUNA VIOS (_P4_) 1.5 VVTi (NCP42_)Saloon 2002 - 200692 / 681NZ-FE TOYOTA YARIS (_P1_) 1.0 (SCP10_)Hatchback 2003 - 200565 / 481SZ-FE TOYOTA YARIS (_P1_) 1.0 (SCP10_)Hatchback 1999 - 200568 / 501SZ-FE TOYOTA YARIS (_P1_) 1.3 (NCP10_, SCP12_)Hatchback 1999 - 200586 / 632NZ-FE TOYOTA YARIS (_P1_) 1.3 (SCP12_, SCP13_)Hatchback 2002 - 200587 / 642SZ-FE TOYOTA YARIS (_P1_) 1.4 D-4D (NLP10_)Hatchback 2001 - 200575 / 551ND-TV TOYOTA YARIS (_P1_) 1.5 (NCP13_)Hatchback 2001 - 2005106 / 781NZ-FE TOYOTA YARIS (_P1_) 1.5 (NCP13_)Hatchback 2000 - 2005150 / 1101NZ-FE TOYOTA YARIS (_P1_) 1.5 (NCP13_)Hatchback 2003 - 2005105 / 771NZ-FE TOYOTA YARIS VERSO (_P2_) 1.3 (NCP20_, NCP22_)MPV 2002 - 200584 / 622NZ-FE TOYOTA YARIS VERSO (_P2_) 1.3 (NCP20_, NCP22_)MPV 1999 - 200286 / 632NZ-FE TOYOTA YARIS VERSO (_P2_) 1.4 D-4D (NLP20_, NLP22_)MPV 2000 - 200575 / 551ND-TVTOYOTA YARIS VERSO (_P2_) 1.5 (NCP21)MPV 2002 - 2005109 / 801NZ-FETOYOTA YARIS VERSO (_P2_) 1.5 (NCP21_)MPV 2000 - 2005105 / 771NZ-FETOYOTA YARIS VERSO (_P2_) 1.5 (NCP21_)MPV 2000 - 2005106 / 781NZ-FETOYOTA YARIS VERSO (_P2_) 1.5 4WD (NCP25)MPV 2000 - 2005106 / 781NZ-FETOYOTA YARIS VERSO VAN (_P2_) 1.3 VVTi (NCP22_)Hatchback Van 2000 - 200586 / 632NZ-FETOYOTA YARIS VERSO VAN (_P2_) 1.3 VVTi (NCP22_)Hatchback Van 2003 - 200584 / 622NZ-FETOYOTA YARIS VERSO VAN (_P2_) 1.4 D4d (NLP22_)Hatchback Van 2001 - 200575 / 551ND-TVTOYOTA YARIS VERSO VAN (_P2_) 1.5 VVTi (NCP21_)Hatchback Van 2000 - 2003106 / 781NZ-FEMore Models for reference
About wheel hub bearing unitWheel hub bearing units keep wheels turning freely and smoothly and also have a critical role in vehicle safety. They incorporate precision bearings and sensors and increasingly include special coatings and greases for higher performance. Mighty offers a wide range of hub units that are applicable to different vehicle types. One design, for instance, features a double row angular contact ball bearing with matched rings and ball-sets to provide the required axial clearance. Variants of this incorporate a flange with the bearing outer ring, while another also has a flange in the rotating ring. There are other refinements to our range, including a unit with improved ABS and TCU sensors. Another is an anti-corrosion coating that simplifies the disassembly of the bearing from the knuckle and rim. Wheel Bearings, Wheel Hubs, Wheel Bearing And Hub Assembly, Right Front Hub Bearing Assembly, Wheel Bearing Hub Assembly Front, Front Wheel Hub And Bearing Assembly, Abs Hub Bearing Assembly, Wheel Bearing Hub Assembly, Hub And Bearing Assembly Front, Left Front Hub Bearing Assembly, Front Wheel Bearing Hub Assembly Replacement, Wheel Bearing & Hub Assembly, Hub Bearing Assembly, front bearing hub replacement, hub and bearing replacement, wheel hub bearings, front wheel bearing hub assembly, front wheel bearing hub replacement, hub bearing assembly front, wheel hub assembly, bearing assembly, Front Wheel Bearing, and Hub Assembly, Front Wheel Drive Hub and Bearing Assembly, Front Axle Bearing & Hub Assembly, Front Bearing Hub Assembly, Wheel Bearing Hub Related Auto Bearings You May Concern
contact me if u need it!
