The acceptable insulation resistance (IR) value depends on the type of electrical equipment, its voltage rating, and industry standards. Here are the general guidelines for common electrical devices and systems:
1. Low-voltage equipment (≤ 1 kV)
For most low-voltage electrical devices (e.g., motors, cables, switchgear), the minimum acceptable IR value is 1 MΩ at room temperature.
A common rule of thumb: IR (MΩ) ≥ Rated voltage (kV). For example, a 400V device should have an IR value of at least 0.4 MΩ.
New or well-maintained equipment typically has IR values well above 10 MΩ.
2. Medium-voltage equipment (1 kV – 36 kV)
The minimum acceptable IR value is usually 10 MΩ or higher.
For medium-voltage cables and transformers, standards like IEC or IEEE often require IR values > 100 MΩ for reliable operation.
3. High-voltage equipment (> 36 kV)
High-voltage devices (e.g., power transformers, transmission lines) demand much higher IR values, typically > 1000 MΩ (1 GΩ).
The IR value should also remain stable over time; a rapid drop in IR indicates insulation degradation.
4. Special considerations
Temperature impact: IR decreases significantly with rising temperature. Most standards specify measurements at 20°C – 25°C, or require temperature correction for accurate comparison.
Megger test standards: When using a megohmmeter, test voltage is matched to equipment rating (e.g., 500V megger for 400V devices, 2500V megger for 10kV devices).
DC systems: For DC circuits (e.g., battery systems), the acceptable IR is generally > 5 MΩ to prevent leakage.
Key industry references
IEC 60034 (rotating electrical machines)
IEEE 43 (insulation resistance testing of rotating machinery)
IEC 60502 (power cables)
