Dec 26, 2025
发表于:2026-9-20 12:43:50|本帖共 1,393 字 1772
       An All-Aluminum Tube-Fin Heat Exchanger is known for its lightweight construction, excellent thermal conductivity, and corrosion resistance. However, like all industrial heat transfer equipment, correct maintenance is essential to preserve performance, extend service life, and prevent costly downtime.
  Proper maintenance ensures stable thermal performance, long service life, and corrosion resistance. Key tasks include:
  1. Regular Cleaning
  Air Side: Remove dust and debris from fins using low-pressure air or soft brushing. Avoid bending fins.
  Water/Oil Side: Flush the internal tubes with clean water or compatible cleaning fluid to remove scale or deposits.
  2. Prevent Corrosion
  Keep the surface dry and clean.
  For coastal or chemical environments, apply anti-corrosion coating if needed.
  Avoid contact with alkaline or acidic chemicals.
  3. Inspect for Physical Damage
  Check fins for deformation and straighten if necessary.
  Inspect tube connections, headers, and manifolds for leaks.
  4. Monitor System Performance
  Track inlet/outlet temperatures and pressure drop.
  Increased pressure drop often indicates fouling or blockage.
  Reduced temperature difference may signal airflow obstruction.
  5. Fan and Airflow Check (if applicable)
  Ensure fans run smoothly without abnormal noise.
  Maintain clear airflow around the heat exchanger.
  6. Seasonal Maintenance
  Before summer: Deep clean fins and confirm fan performance.
  Before winter: Check for moisture and corrosion.
  7. Avoid Harsh Cleaning Methods
  Do not use high-pressure water, steam jets, or strong chemicals that may damage aluminum.
  Use pH-neutral cleaners only.
