Swimwear will inevitably lose color and fade after several uses due to factors like dye leakage and fabric wear. Often, fading is only noticed once it becomes prominent. Understanding the causes of fading and ways to recover color is essential.
• Over-washing: If you wash your swimwear in the machine after every use, it may appear dull or faded. Washing too often can damage the fabric, causing both fading and loss of proper shape or fit.
• Hard water: Pool water contains various chemicals and minerals such as calcium and magnesium. These raise the pH level of the water, which can damage skin and swimwear. Most importantly, it can cause clothing to fade and turn white quickly, and severely damage the fabric.
• Excessive chlorine content: Chlorine buildup is another major reason why swimwear fades over time. This chemical acts like a bleach on the fabric. This means that if not rinsed immediately, it will leave irregular white patches on the swimwear, making it appear noticeably faded. If you are using a detergent containing bleach, chlorine, optical brighteners, or phosphates, the swimwear will fade even faster.
• Sun exposure: Never expose swimwear to direct sunlight, as UV rays will dry out the fabric and make it brittle. Hang or lay flat in a cool, shaded area to air-dry naturally.
So, when the swimwear color fades, how can it be made bright again? Here are some tips for you :
• Saltwater Soak: For new swimwear, soak in saltwater briefly to lock in color and prevent fading. That is because Vinegar breaks down mineral residues from detergents or hard water, restoring brightness. The best vinegar treatment should be diluted white vinegar in water, and soak the swimwear for 20-30 minutes.
• Baking Soda Boost: Add a small amount of baking soda while hand-washing, or use sparingly in a washing machine as an alternative. It revives vibrant colors, especially for white fabrics.
• Black Pepper Trick: For deep cleaning, mix 2-3 spoons of black pepper into water with hand washing. It helps break down leftover detergent residues.
• Coffee/Tea Refresh: Brew 470 ml of strong black tea or coffee. Soak the black swimwear in the mixture to restore its color and keep it looking new.
Following the above cleaning and maintenance tips can effectively prevent swimwear from fading and extend its lifespan.
