NSK rolling bearing features, NSK rolling bearings and sliding bearings have the following features:
The starting friction is small, and the difference between the sliding and the control is also small. The standardization and standardization are promoted internationally, and the interchangeability is good, and can be used interchangeably among different brands. With reference to the NSK bearing standard and the SKF bearing standard, it can be seen that the standards for imported rolling bearings are common.
It simplifies the construction around the imported bearings for easy maintenance and inspection. It is generally possible to withstand both radial and axial loads. It is easier to use under high and low temperature conditions.
In order to increase the rigidity, it can be used even in a negative gap (preload state). Each structure of the NSK rolling bearing has its own characteristics. |
