The material selection of the coaxial heat exchanger directly affects its heat exchange efficiency, corrosion resistance, service life and cost. The following are the three core principles and purchasing suggestions based on actual application scenarios and technical requirements:
I. The principle of giving priority to corrosion resistance
Core requirement: The material must be adaptable to the corrosiveness of the medium (such as acid, alkali, salt solutions or seawater).
• Recommended materials:
Titanium alloy: It has extremely strong resistance to seawater and chloride ion corrosion and is suitable for Marine engineering or seawater desalination systems.
Hastelloy/nickel-based alloys: Resistant to strong acids (such as sulfuric acid, hydrochloric acid) and high-temperature oxidation environments, suitable for the chemical industry.
• 316L stainless steel: High cost performance, resistant to general corrosive media, widely used in the food and pharmaceutical industries.
• Pitfalls Avoidance Tips:
Avoid using ordinary carbon steel as it is prone to rust and has a short lifespan.
Refrigerants such as Freon should be kept away from direct contact with copper (which may cause electrochemical corrosion).
Ii. Principles for Optimizing Thermal Conductivity Performance
Core requirements: High thermal conductivity of the material to reduce thermal resistance and enhance heat exchange efficiency.
Pure copper/red copper: With a thermal conductivity of up to 400 W/(m·K), it is suitable for high-precision temperature control scenarios (such as medical cold chain).
• Aluminum: Lightweight and with good thermal conductivity (237 W/(m·K)), but surface oxidation treatment is required for corrosion prevention.
Nickel white copper: It combines corrosion resistance and thermal conductivity, making it suitable for seawater heat pump systems.
• Technical details:
The spiral grooved tube design can enhance turbulence and make up for the insufficient heat conduction of some materials.
The double-layer copper tube structure (inner and outer copper layers) can further enhance the heat transfer efficiency.
Iii. The principle of balancing mechanical performance and cost
Core requirements: The material must meet the demands of pressure resistance and vibration resistance, while controlling the overall cost.
• Recommended material combinations:
• Inner tube: Stainless steel + outer tube: red copper: It combines pressure resistance (stainless steel) and heat conduction (copper), with a moderate cost.
• Titanium inner tube +316L stainless steel outer tube: Suitable for highly corrosive and high-pressure working conditions (such as ground source heat pumps), but with a relatively high cost.
• Cost control strategy:
For normal working conditions, 304 stainless steel or red copper is preferred.
For special working conditions (such as high temperature and high pressure), nickel alloys or titanium materials are used, and the long-term operating benefits need to be evaluated.
Application scenarios and material compatibility table
Advantages of scene recommendation material combinations
The common air-cooled heat pump with a copper inner tube and a steel outer tube has a low cost and high heat conduction efficiency
The titanium alloy inner tube and 316L stainless steel outer tube of the seawater source heat pump are resistant to seawater corrosion and have a long service life
The stainless steel inner tube and copper outer tube of the pharmaceutical cold chain (clean environment) are easy to clean and meet GMP standards
The inner tube of Hastelloy alloy and the outer tube of nickel for industrial waste heat recovery are resistant to acids and alkalis and high-temperature creep
Purchasing Tips
1. Verify material certification: Require suppliers to provide material test reports (such as ASTM, GB standards);
2. Pay attention to the weld process: Argon arc welding or laser welding can reduce the risk of intergranular corrosion;
3. Customized design: Adjust the pipe diameter and spiral structure according to the flow rate and temperature difference requirements to avoid "a big horse pulling a small cart".
By following the above principles, materials and working conditions can be precisely matched to achieve the optimal balance of performance, cost and reliability.
