Advantages of microcrystalline ceramic nano heating magnetic stirrer
发表于:2026-9-16 11:09:35|本帖共 1,831 字 1946
       Advantages of microcrystalline ceramic magnetic heating plate:
  Microcrystalline ceramic magnetic heating plate Microcrystalline ceramic magnetic heating plate Microcrystalline ceramic nano heating magnetic stirrer
  HMS-901A Digital Display Heating Magnetic Stirrer
  product manual:
  -Using NanoHeat world-class thermal energy technology drive, no mechanical heating components, dry burning, no electromagnetic field interference and harm,
  -Ultra-fast heating technology can increase the temperature at a rate of 5 ° C per second, the surface temperature of the board is uniform, and the temperature difference is 1-3 ° C. The temperature difference of the liquid can be accurate to 0.1 ~ -0.5 ℃, and it only takes 8 minutes to heat up to 450 degrees.
  -LED display, can set the specified temperature, built-in temperature probe and external temperature probe, can be switched freely.
  -Over temperature alarm function, set temperature timer function, more convenient experiment
  -Germany SCHOTT microcrystalline ceramic plate surface, acid resistance, alkali resistance, corrosion resistance, easy cleaning.
  -Stable mixing performance, using DC motor, low noise, long life, stable at low speed, strong at high speed;
  -Free from magnetic interference and hazards: making it a good choice for medical and laboratory use
  -Suitable for most appliances: glass, ceramic and metal utensils
  -Widely used in industrial, agricultural, chemical, pharmaceutical, biological and other experimental heating and stirring.
  Product Features;
  Heating output power: 800W
  Surface temperature control: room temperature to 450 ° C
  Temperature control mode: LED digital display temperature free setting
  Temperature test: built-in temperature control and external temperature control can be switched
  Temperature control accuracy: ± 0.5 ℃
  Stirrer drive: ND servo motor, output power: 9W
  Speed range: 0 ~ 2000rpm
  Speed control: speed digital display, stepless speed regulation
  Maximum stirring amount: 10L
  Working size: 240 × 240mm
  Product dimensions: 370 × 130 × 240mm
  Gross weight: 6.7kg
  Surface material: German SCHOTT microcrystalline ceramics
