Do you know the LED lamp features
发表于:2026-9-14 09:46:45|本帖共 572 字 1970
       1, Widely uses. LED lamp is basically a small chip is encapsulated in epoxy resin inside, so it is very small, very light.
  2, Low power consumption, low power consumption is very low LED lamp. 3, Long service life. Under the appropriate current and voltage, the service life of LED lamp can be up to 100 thousand hours. High brightness, low heat. 4, Environmental protection. LED lamp is made of non-toxic materials, unlike fluorescent mercury containing mercury will cause pollution, while LED lamp can also be recycled.
  If you also need high quality lamps, we can supply incandescent light bulb, fluorescent lamp, halogen bulb etc. Welcome to contact us to learn more about our lamps.
