The micro switch also has a name called Quick Switch, it sometimes has problems with the circuit, then how to solve this problem? The following micro switch manufacturers bring effective solutions.
There are many types of micro-switches. They can be divided into many types regardless of volume or internal construction, but the application effects are roughly the same, and the production principles are similar. First of all, the sensitivity is satisfactory. The most important thing about electronic products is the sensitivity. No matter how many areas you divide, if you cannot satisfy customers with sensitivity, this product will eventually be eliminated by the market. What factories in the micro switch industry need to do is to do the best in the handling of various components, especially the degree of response of the shrapnel.
If there is a problem with the micro switch circuit, first look at whether there are obvious damages to the electronic components, such as the discoloration of the resistor, the bulging of the electrolytic capacitor, and the flow of liquid. Then you should check in sections, one is to check whether the power supply is normal, the other is to check the micro-movement Whether the switch is in good condition, then check whether there is any problem with the switch signal input circuit and whether the execution unit is working.
