DERFLEX is a professional manufacturer and global supplier of Water Diversion Tubes designed for flood control, emergency drainage, municipal diversion, irrigation projects and industrial water management. Made from reinforced PVC coated fabric, the tubes provide outstanding tensile strength, hydrostatic resistance, abrasion durability, and long service life under harsh outdoor environments.
With more than 20+ years of experience in PVC industrial textiles, DERFLEX offers custom sizes, thickness, pressure rating and connection systems to support large engineering projects worldwide.
The Water Diversion Tube, also called Flexible Water Diversion Pipe, Emergency Flood Control Tube, or PVC Water Control Tube, is a collapsible, flexible, and high-capacity water conveyance structure made from heavy-duty PVC coated industrial fabric. Unlike rigid pipes, it provides lightweight transport, fast deployment, and large-volume water transfer capacity.
Water diversion tubes are widely used in:
The flexible structure allows easy storage, transport, and quick coupling using customized connectors, making it ideal for rapid-response projects.
DERFLEX uses industrial-grade PVC coated polyester fabric designed for strong mechanical performance under high water pressure and rough ground contact.
We manufacture **custom diameters, wall thickness, pressure rating, roll lengths and connection methods**.
All tubes are produced using **HF welding or hot-air welding** for 99% airtight and watertight performance.
Suitable for long exposure to sunlight, rain, mud and high-flow water environments.
DERFLEX engineers can support specialized designs including:
Rapid water evacuation for towns, farmland, underground parking, basements, and low-lying areas.
Used for temporary or permanent river flow redirection during construction or maintenance.
Drainage pipe bypass, pipeline maintenance, temporary water route setup.
Large-capacity water transport for irrigation channels, dryland farming, and rural water projects.
Transfer water for bridge foundations, tunnels, subways, hydroelectric projects.
Chemical plants, mining sites, industrial drainage and water transfer operations.
DERFLEX, founded in 2001, is a leading manufacturer of PVC coated fabrics, technical textiles and engineered flexible materials for industrial and environmental applications. With more than 20+ years of manufacturing experience, DERFLEX exports to over 120+ countries worldwide.
DERFLEX has supplied Water Diversion Tube materials for large engineering and emergency projects in:
Yes. We provide **200 mm to 3000 mm** in any required length.
3–5 years for outdoor use; up to 8–10 years with proper handling.
Yes. Pressure rating ranges from **0.2–1.2 MPa** depending on thickness.
Using welded couplings, zippers, flanges, or custom-designed systems.
DERFLEX PVC formulation is non-toxic, lead-free, and compliant with international safety standards.
