Definition Of Water Jet Cutting
发表于:2026-9-6 12:51:54|本帖共 614 字 4791
       Water jet cutting is a kind of plane cutting machine which combines the ultra-high pressure water jet generator and two-dimensional NC machining platform. It raises the pressure of water flow to a high enough level (above 200MPa), which makes the water flow have great kinetic energy, and can penetrate chemical fiber, wood, leather, rubber, etc. when mixing a certain proportion of abrasive in high-speed water flow, it can penetrate almost all hard materials such as ceramics, stone, glass, metal, alloy, etc. Under the guidance of the two-dimensional NC machining platform, start or finish machining at any position of the material, move at a proper speed according to the set track, and realize the plane cutting of any figure.
