DAIFUKU CLW-3790A 控制器板 PDF资料
1.产 品 资 料 介 绍:
DAIFUKU CLW-3790A 控制器板产品特点
DAIFUKU(大福)是日本的物料搬运系统制造商,CLW-3790A 是其旗下的一款控制器板,主要用于工业自动化设备控制。其主要特点如下:
专为 DAIFUKU 工业设备设计,适配性强。
采用锌合金外壳,表面经过微光磨砂和防指纹镀层处理。
金属外壳提供良好的抗冲击保护和散热性能。
接口插拔寿命超过5000次,耐用性高。
有效改善老旧设备信号传输不稳定的问题。
采用柔韧编织线缆,抗拉扯,不易打结。
适用于 DAIFUKU 输送系统、自动仓库等设备。
作为控制系统接口板,承担信号传输与设备控制功能。
产品设计注重长期稳定运行,减少维护频率。
符合工业级电磁兼容和安全标准。
支持与 DAIFUKU 控制系统无缝集成。
模块化设计,便于安装和更换。
适用于物流、仓储、制造业等工业自动化领域。
由日本 DAIFUKU 品牌设计制造,品质有保障。
可作为备件或升级部件,替换老旧设备中的同类控制板。
综上,DAIFUKU CLW-3790A 是一款耐用性强、信号稳定的工业控制器板,适合用于 DAIFUKU 物流自动化设备中作为控制或接口组件。
DAIFUKU CLW-3790A 控制器板 英文介绍
Product Features of DAIFUKU CLW-3790A Controller Board
DAIFUKU is a well-known material handling system manufacturer in Japan, and CLW-3790A is one of its controller boards mainly used for industrial automation equipment control. Its main characteristics are as follows:
Specially designed for DAIFUKU industrial equipment, with strong adaptability.
Adopting a zinc alloy shell, the surface is treated with micro matte and anti fingerprint coating.
The metal casing provides excellent impact protection and heat dissipation performance.
The interface has a plug-in life of over 5000 times and high durability.
Effectively improve the problem of unstable signal transmission in old equipment.
Using flexible braided cables, resistant to pulling and not easily knotted.
Suitable for DAIFUKU conveying systems, automatic warehouses, and other equipment.
As a control system interface board, it is responsible for signal transmission and equipment control functions.
Product design emphasizes long-term stable operation and reduces maintenance frequency.
Compliant with industrial grade electromagnetic compatibility and safety standards.
Support seamless integration with DAIFUKU control system.
Modular design, easy to install and replace.
Suitable for industrial automation fields such as logistics, warehousing, and manufacturing.
Designed and manufactured by the Japanese brand DAIFUKU, with guaranteed quality.
Can be used as spare parts or upgraded components to replace similar control boards in old equipment.
Overall, DAIFUKU CLW-3790A is an industrial controller board with strong durability and stable signal, suitable for use as a control or interface component in DAIFUKU logistics automation equipment.
DAIFUKU CLW-3790A 控制器板 产品图片
3.其他产品
5SHY3545L0014 3BHB013085R0001工业运动传感器 AO2000-LS25 激光分析仪 3BHB045647R0003 励磁可控硅模块
4.其他英文产品
IC698CPE040-JP combustion engine card IMHSS03 Voltage dc module YASKAWA JGSM-06 73051-00060 Logic input module
本篇文章出自瑞昌明盛自动化设备有限公司,转载请附上此链接:
