Sudden Yarn Quality Issues in Spinning: Causes and Practical Solutions
发表于:2026-9-6 09:11:03|本帖共 5,419 字 1440
       The yarn spinning process involves a vast range of accessories and is subject to complex variable factors, including manual operation habits, spinning process parameters, and workshop air conditioning conditions. These unstable factors easily trigger sudden equipment abnormalities and unexpected yarn quality defects, such as uneven yarn evenness, fabric streaks, and batch quality failures. This article systematically analyzes mainstream sudden quality issues caused by faulty equipment conditions and non-standard manual operations, elaborates their defect formation mechanisms, and provides practical prevention and control solutions for textile production.
  Most sudden yarn quality defects in mass spinning production stem from worn accessories, structural abnormalities and abnormal operation of the drafting and transmission systems. The typical equipment-induced quality problems and root causes are analyzed in detail below.
  Local gouging, circumferential grooving and surface abrasion of front rubber rollers are common mechanical faults in spinning production. Damaged roller surfaces cannot firmly grip and constrain fibers during high-speed drafting, resulting in uneven fiber control. This issue directly deteriorates yarn evenness, causes irregular yarn thickness deviation, and seriously undermines overall yarn quality stability.
  Excessive fiber wrapping on rollers and rubber rollers frequently causes pressure attenuation and failure of top cradle springs. This prevents the upper and lower cradles from forming a stable elastic drafting nip. In severe cases, the top cradle floats upward and completely loses effective restraint on running fiber strands.
  This malfunction generates severe drafting waves, which greatly damage yarn evenness and produce frequent long-thick and long-thin yarn defects. These hidden flaws will eventually form irregular striping and uneven texture on finished woven fabrics, reducing fabric appearance grade.
  Stagnant and blocked top apron movement is mainly caused by fiber accumulation in cradle and apron gaps, insufficient pressure of the middle-top roller, and top cradle deformation. Once the top apron moves sluggishly or gets stuck, the roving strand in the rear drafting zone will become loose and slack.
  Without effective rear-zone pre-drafting and fiber arrangement, loose roving directly enters the front drafting zone, reducing inter-fiber friction and stable control. This leads to poor yarn evenness, abnormal drafting efficiency, off-count fine yarn, and continuous thin horizontal streaks on fabric surfaces.
  Furthermore, severely blocked aprons cause periodic stuttering and intermittent operation hesitation. This creates regular fiber disturbance at the drafting nip. Mechanical waves generated in the rear drafting zone are amplified by front-zone drafting, forming long-wavelength periodic yarn defects that seriously damage fabric uniformity.
  Damaged transmission gears, drive shafts, fixing pins and key power components cause unstable mechanical operation and inconsistent drafting ratios. Unlike partial local defects, transmission system faults affect the entire yarn batch, triggering large-scale unqualified products and massive economic losses.
  Accordingly, regular equipment cleaning, standardized lubrication and periodic inspection of key transmission parts are essential maintenance measures to eliminate hidden mechanical faults and stabilize spinning yarn quality.
  Non-standard manual operation is one of the most common and easily overlooked sources of sudden spinning quality defects. Irregular yarn piecing, doffing and spindle cleaning operations often cause abnormal yarn count, insufficient twist and batch fabric quality problems.
  During product switching or post-doffing yarn piecing, individual operators casually use personal spare yarn for splicing. If the piecing yarn differs in count, raw material or fiber composition from formal production yarn, wrong-count yarn defects will occur.
  Although defective piecing yarn features short segment length, it poses greater quality risks than conventional wrong-count bobbins. Such defects are widely distributed and highly recurrent: simultaneous operation by multiple workers during product switching easily causes large-area defective yarn, while concealed fault causes make detection and eradication difficult.
  Wrong-count yarn leads to obvious long thick and thin strips on fabrics. Yarn with inconsistent fiber composition presents different dye absorption rates, forming prominent horizontal streaks after dyeing and greatly reducing fabric finished grade.
  Prevention Solutions: Improve staff quality awareness and strictly prohibit random piecing with non-designated yarn; prepare exclusive piecing yarn in advance for product switching; implement workshop isolation and dedicated operator allocation for products with distinct fiber differences; completely remove residual heterogeneous yarn on bobbins and equipment before switching production batches.
  Careless manual operation during doffing and spindle base cleaning may cause the spindle tape to slip off the spindle whorl and latch onto the whorl edge. The larger edge diameter reduces spindle rotating speed, resulting in insufficient yarn twist and forming typical weak-twist yarn defects.
  Production tests verify that spindle tape misalignment reduces yarn twist by 15%–20%, loosens yarn internal fiber structure, and creates visible horizontal streaks on dyed finished fabrics.
  Prevention Solutions: Strengthen operator standard operation training and implement targeted workshop inspections and performance assessments. Replace traditional bristle brush cleaning with pneumatic twisting guns to remove fly waste and fiber deposits, effectively avoiding spindle tape deviation and weak-twist yarn defects.
  In conclusion, sudden spinning quality defects mainly derive from worn equipment parts, abnormal mechanical operation and non-standard manual procedures. Textile enterprises should adopt standardized equipment maintenance, strict operating specifications and rigorous on-site management to eliminate quality hazards at the source, stabilize yarn evenness and twist consistency, and upgrade overall finished textile product quality.
