How to maintain and reduce wear of the blades of the pulverizer?
发表于:2026-9-1 10:55:17|本帖共 949 字 3427
       Daily maintenance is important to reduce the wear and tear of the grinding machine blades. Firstly, before each use, it is necessary to check whether the blade is securely installed and whether there are any signs of looseness, in order to avoid further wear or danger caused by blade looseness during high-speed operation; During use, the grinding parameters should be adjusted reasonably according to the characteristics of the material to avoid overload operation. For example, for materials with high hardness, the feeding speed should be appropriately reduced to prevent the blade from bearing excessive impact force; After use, promptly clean the residual plastic debris and impurities on the blade to avoid these substances accumulating on the blade, affecting the next use and exacerbating blade corrosion; Regularly lubricate the blades by applying an appropriate amount of lubricating oil to the rotating parts of the blades to reduce friction; In addition, the blades can be regularly sharpened to maintain their sharpness, which can reduce wear to a certain extent and extend their service life.
  Related videos
