The characteristics of Marzocchi gear pumps are: good hydraulic function, mechanical and volumetric efficiency, low noise level, not only that, but also compact size and low weight/power ratio.
The product range of Marzocchi gear pumps has GHP series: GHP1, GHP2, GHP3 suitable for various industrial and mobile applications. Usually these gear pumps are usually composed of two aluminum bushings, the body, and a special sleeve compensation belt, which is insulated by a special pre-formed seal back-extrusion ring, which allows complete free axial and radial movement of the sleeve. The working pressure of the pump is proportionally adjusted. In this way, the same series can provide different flanges and forms of equiaxed extension ports.
The following can be provided: · Pressure limiting valve · High pressure pump · Two-way pump · Hydraulic motor-one-way and two-way · Diverter · Multi-stage pump with standard components
The following special applications can be provided:
V-High temperature fluid application,
The temperature range is between -10°C and +120°C, with the maximum pressure valve not exceeding +80°C, and the maximum operating pressure must not be exceeded.
Only available for certain series of products, the maximum pressure of 20bar does not exceed +150°C (please specify the actual parameters when ordering) TR- applies to the maximum inlet pressure of 6bar.
ST- is suitable for high and low temperature fluid applications, ranging from -40°C to +120°°C, only certain series are available.
W- is suitable for glycol water and low lubrication power applications. It is recommended that the speed does not exceed 1000 rpm and the pressure does not exceed 100 bar, only certain series are available.
VW-Suitable for the application of phosphorus-containing ester media. It is recommended that the speed does not exceed 1000 rpm and the pressure does not exceed 100 bar, only certain series are available.
