This new type of pesticide is called the bodyguard of the plant, it only needs to be used 3 times, and it is not sick in a season
发表于:2026-8-26 12:57:11|本帖共 4,771 字 1294
       Crop diseases and insect pests are the most important factors affecting the normal development of crops, especially viral diseases, root rot and other stubborn diseases. In order to prevent and control diseases, farmers have to spray various pesticides frequently and invest a lot of manpower and material resources. Today, I would like to recommend a new type of pesticide, called "the bodyguard of plants". It only needs to be used three times. It has a good defense against many diseases, and basically it will not get sick in one season.
  Introduction
  This new drug is chitosan, a substance produced by heating chitin (chitin) under alkaline conditions. The appearance is a white or light yellow translucent solid with a slight pearly luster and can be directly dissolved in water. . Chitosan is praised by European and American academic circles as the sixth vital element after protein, fat, carbohydrates, vitamins and inorganic salts.
  It is widely used in food, medicine, cosmetics, health care products, agricultural production and other fields. It is practical in agriculture and has a good control effect on various diseases. It significantly increases the yield of crops and improves the variety of crops. It is called "Plant vaccines" are becoming more and more popular among farmers.
  Main function
  (1) Promoting plant growth: Chitosan can lengthen cell walls, has the effect of promoting plant growth and development, and can significantly increase the germination rate of crops, increase the weight of individual plants, promote root growth, and increase leaf area.
  (2) Improve immunity: Chitosan can change the structure and function of the cell membrane of pathogens, thereby inhibiting the growth of pathogens, and improving the immune functions of crops such as disease prevention and disease resistance.
  (3) Improve yield: Chitosan can enhance seed germination by dressing, soaking, coating and other methods to treat seeds, so that the seeds will emerge early, the whole seedlings will emerge, and the seedlings will be strong. Significantly promote the growth and development of plants. Activity experiments on fruits, vegetables, and food crops and field experiments have proved that chitosan can increase crop yields by 10%-30%.
  (4) Disease prevention and control: Chitosan used for seed dressing can change the soil microbial flora, promote the growth of beneficial microorganisms and inhibit some plant pathogenic bacteria. Chitosan can also change the structure and function of the cell membrane of pathogenic bacteria, thereby inhibiting the growth of pathogens and achieving the purpose of disease prevention and control.
  (5) Non-toxic and non-polluting: The raw material of chitosan is mainly derived from the shells of marine organisms such as shrimps and crabs. It is a substance that is more easily absorbed by crops and does not pollute the environment, humans, or environmental organisms.
  (6) Super adsorption capacity: A significant feature of chitosan is adsorption capacity, which can adsorb calcium, magnesium, zinc, potassium and other metal ions in the soil, significantly improve nutrient utilization, and prevent crops from lacking trace elements.
  (7) Good compatibility: Chitosan has good compatibility, and can be used with prochloraz, tebuconazole, thiazophos, azoxystrobin, choline chloride, etc. Growth regulator compounding.
  How to use
  (1) Seed dressing treatment: Before sowing soybeans, cabbage, corn, wheat and other crops, spray 1% chitosan solution directly on the seeds, and stir while spraying, so that the seeds are evenly coated with the chitosan solution. It can effectively prevent soil-borne diseases such as root rot, sheath blight, and total rot, and significantly promote root development and plant growth, with few diseases, and significantly increase crop yields.
  (2) Promote fruit swelling: in the early stage of the swelling of underground roots and tubers of potato, ginger, garlic, sweet potato, yam and other crops, use 23% chitosan·choline chloride solution 30-50ml/mu with water for 30 Evenly spraying a kilogram, spraying 2 to 3 times in a row, can significantly promote the expansion of underground roots and tubers, and increase the yield by more than 60%. It can also prevent the occurrence of underground diseases.
  (3) Prevention and treatment of downy mildew and anthracnose: For the prevention and control of downy mildew such as cucumber, grape and cabbage, 16% chitosan. Azoxystrobin suspending agent 55-60 ml/mu can be used, and 30 kg of water can be sprayed evenly, which can be effectively controlled. Occurrence and harm of diseases.
  (4) Prevention of root knot nematodes: To prevent root knot nematodes of cucumbers, tomatoes, watermelons, melons and other crops, 15% chitosan·thiazolyl phosphine granules 1000-1500 g/mu can be used for furrow application or pitting before planting the crops. It can effectively prevent root-knot nematode damage, and at the same time, it can also prevent underground diseases and promote crop growth.
  (5) Fruit preservation: After harvesting fruits such as apples, pears, peaches, strawberries, etc., spray them with 0.1% chitosan solution on the surface of the fruits or vegetables. Since the surface of the fruit forms a protective film, it prevents the invasion of pathogens and inhibits them The growth can achieve the purpose of preservation.
  Zhengzhou Delong Chemical CO., Ltd. is the production base of plant growth regulators in China, which established in 2009, specializing in offering plant protection products. If you have any question, contact us any time.
这篇文章看到了危机中的机遇。
3 天前|本帖共 14 字 回复
