ZVB4 2端口ZVB8现货网络分析仪
ZVB4
Rohde&Schwarz ZVB4 4G矢量网络分析仪|罗德与施瓦茨 300kHz至4GHz
:罗德与施瓦茨 Rohde&Schwarz The R&S®ZVB series of vector network analyzers covers the frequency ranges from 300 kHz to 4/8 GHz and from 10 MHz to 14/20 GHz. It has been designed for universal measurements0n passive and active components. The R&S®ZVB series greatly simplifies vector network analysis especially for multiport measurements and measurements0n balanced devices. Featuring comprehensive measurement functions, excellent specifications, high measurement and data transfer speeds and remote-control capability, the analyzers of the R&S®ZVB series are an ideal choice for both development and production applications. The compact versions of the 14 GHz and 20 GHz two-port models leave ample room for test setups in the lab, featuring a height of0nly 24 cm and a depth of 42 cm.
ZVB4 2端口ZVB8现货网络分析仪
New multiport concept Instruments with two or four test ports – for multiport and balanced measurements Two internal sources (four-port models) – to provide RF and LO signals for mixer measurements by means of a single unit Capability to perform balanced measurements – to characterize balanced DUTs by their mixed mode S-parameters Optional automatic calibration units – to speed up calibration and avoid operator errors Outstanding specifications 60001 points per trace Dynamic range better than 123 dB (typ. 130 dB) Power sweep range >50 dB High speed Measurement time Switching time between channels Switching time between instrument setups
ZVB8ZVB8价格供应ZVB8的详细资料
R&SZVB矢量网络分析仪适用于无源器件和有源器件的通用测量,它的频率范围有300KHz至8GHz和10MHz至20GHz。R&SZVB使矢量分析变得更加简单,特别是对于多端口器件和平衡器件的测量而言。由于它那测量功能、出色的技术指标、快速的数据采集传输能力和的远程控制能力,使得R&SZVB成为研发和生成的理想设备。
ZVB4 2端口ZVB8现货网络分析仪
崭新的多端口理念 ◆仪器有2/3/4个端口 ◆多端口处理能力 ◆平衡测试能力 ◆校准单元,频率高达24GHz;
突出的指标 ◆每条轨迹曲线20001点 ◆动态范围优于123dB ◆功率扫描范围50dB
高速 ◆测量时间: ◆通道间切换时间: ◆设置间切换时间: ◆数据传输时间: ◆可以同步测量多于一个待测件
现代的用户界面 ◆基于Windows系统、鼠标操作直观 ◆热键、软键操作 ◆大量的通道、轨迹数 ◆并行设置管理 ◆操作向导:例如平衡器件测量和校准 ◆集成的嵌入/去嵌功能
连接 ◆兼容传统的设计工具 ◆轨迹数据在PC和R&SZVB之间双向传输 ◆通过GPIB和LAN口远程控制 ◆数字I/O接口 ◆USB连接
ZVB4 2端口ZVB8现货网络分析仪特征 1)用于优化产能的功能 R&SZVB的新平台采用了基波混频技术,ZVR系列矢网已经采用了该项技术10年。它的动态范围为123dB,轨迹噪声小于0.01dB,测量带宽的范围是1Hz-500kHz。在测量带宽为500kHz时,201点的测量扫描时间小于8ms。
通过分段扫描的方式还可以进一步优化测量时间,分段的数量受限于仪器的内存。每一个频段内的扫描参数(如频点间隔、测量带宽、源电平)都可以独立设置以适合待测件的测试。
不同的设置能以文件的形式存贮在硬盘中,与此同时也能加载到仪器的内存中,每个设置代表了一个独立的窗口。在手动模式下,通过鼠标简单的点击下就可以切换不同的设置(设置-切换);在远程控制模式下,通过设置切换可以缩短相当的切换时间。一旦调用这些设置(包括校准数据)就会自动保存在RAM中,这样就可以在10ms之内通过IEC总线迅速地切换不同的设置。由于在数据采集的同时,轨迹数据也在通过IEC/IEEE总线或LAN口进行传输,因此R&SZVB的数据传输时间也就可以忽略不计了。
基于多源理念的R&SZVB允许对测试端口分组。在“端口管理器”对话框里可以定义进行平行测量的配置。每个端口组可以相对于其他组独立地进行测量,这样所有的组就可以同时并行测量,因而多个待测件或一个待测件的多个端口就可以同时测量了。
2)现代的用户界面 用矢网进行复杂的测量,特别时进行多端口的应用时,需要一个直观易懂的操作界面。R&SZVB提供了简单易懂的操作界面,有利于未经培训的或很少使用仪器的用户。尽管它有着很多的测量端口和测量参数、众多的显示图框和轨迹以及的功能,R&SZVB的基本测量任务还是很容易完成的。
即使是那些对网络分析仪很熟悉的用户,也会很欣赏R&SZVB的操作界面的。
除了可靠的热键和软键外,R&SZVB还提供了可以用鼠标选择的下拉菜单选项。鼠标选择的菜单结构和热键/软键结构的安排一样,这样就可以使用这两种方式在同样的位置寻找需要的功能项。
辅助以对话框,还可以方便地管理大量的测试端口、测试参数和测试轨迹。R&SZVB的测量向导包括复杂的操作程序,如平衡器件的校准与测量等。对于标准的测量,用户在向导的指引下可以一步一步地设置仪器。
无需进行复杂的菜单变换,仅仅通过几次简单的按键或点击鼠标,就可以迅速地将轨迹配置给特定的图框和通道。
热键组中还提供了一些辅助的功能,如在线帮助、设备硬件信息、当前的配置。前后连贯的在线帮助是软件升级的一部分,它同时有包含了的产品信息。
R&SZVB还有一个非常新颖的UNDO功能-可以返回到之前的若干部操作,哪怕是将仪器复位了,也同样可以撤销返回。因此,由误操作引起耗时的重新设置已经成为过去。 另外,的轨迹数学功能允许所有的轨迹实时地关联合并。编辑的公式可以保存也可以传送到其他设备。
3)校准方法、自动校准
由于每个端口都配有独立的测量接收机和参考接收机,R&SZVB像它的前代产品一样也提供了所有的校准方法。
R&SZVB提供了经典的TOSM校准法(直通、开路、短路、匹配负载),也称为SOLT法(短路、开路、负载、直通)。除了TOSM法和多端口校准法之外,R&SZVB还提供了7项误差模型校准法,如TOM(直通、开路、匹配),TRL(直通、反射、线),TRM(直通、反射、匹配)和TNA(直通、网络、衰减)。其中TNA法适用于测试夹具的校准。
7项误差模型校准法有很大的优点,它不但减少了校准件的数量,还可以采用一些参数未知的标准件,而得到的校准精度和TOSM法是相同的。
除了上述的手动校准方法之外,也可以通过电子校准单元进行自动校准,校准时间大约为20秒。
校准单元R&SZV-Z51(上限到8GHz)和ZV-Z52(上限到24GHz)可以对R&SZVB系列矢网的端口(1-4个)进行自动校准。仅仅通过简单的连接加上几步简单的操作就可以完成,而手动校准则需要若干个机械校准件外加上仔细的操作才能完成。
只需半分钟的时间,网络分析仪就可以完成一个4端口校准(系统误差修正),而后可供测量使用。校准单元的接头形式为N型(阴头)和3.5mm(阴头)。
该设备结构紧凑,重量小于20Kg,尺寸只有44cmx23cmx35cm。
