Dualex是一款源自于法国国家(CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进a行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。 此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
摘要
与其他主要作物不同,很少有人对番茄进行研究,以减少快速繁殖的世代时间。我们在M82(确定)和Moneymaker(不确定)品种中评估了几种缩短番茄世代时间的农艺处理,并结合胚胎挽救评估了组合。在秋季周期的个实验中,评估了从0.2升(XS)到6升(XL)的五种容器尺寸。我们发现,XL容器中的植物表现出更好的发育,从播种到开花(DSA)和开花到果实成熟(DAR)所需的时间更少。在第二个实验中,在秋冬周期中使用XL容器,我们评估了子叶期的冷启动、水分胁迫、磷补充和钾补充对世代的影响。我们发现,与对照相比,冷启动显著降低了叶片数量和花序的株高以及DSA(2.7 d),而补钾降低了DAR(8.8 d)。这些处理对其他生理性状的生长没有观察到任何影响。在春季-夏季循环中使用XL容器的第三个实验中,测试了冷启动加K补充的组合,证实了该组合对生成时间的显著影响(DSA为2.9天,DAR为3.9天)。在细胞扩增周期(M82和Moneymaker开花后平均分别为22.0天和23.3天)期间的胚胎挽救使M82和Moneymaker的生成时间与植物内果实成熟相比分别缩短了8.7天和11.6天。将农艺处理与胚胎挽救相结合,可以有效地将番茄快速育种的年代数从目前的三代增加到四代。
关键词:番茄茄,世代时间,快速繁殖,容器大小,冷启动,补钾,胚胎挽救。
Abstract
Unlike other major crops, little research has been performed on tomato for reducing generation time for speed breeding. We evaluated several agronomic treatments for reducing the generation time of tomato in the M82 (determinate) and Moneymaker (indeterminate) varieties and evaluated the best combination in conjunction with embryo rescue. In a first experiment under the autumn cycle, five container sizes, from 0.2 l (XS) to 6 l (XL), were evaluated. We found that plants from the XL containers exhibited better development and required less time from sowing to anthesis (DSA) and for anthesis to fruit ripening (DAR). In a second experiment, using XL containers in the autumn-winter cycle, we evaluated cold priming at the cotyledonary stage, water stress, P supplementation, and K supplementation on generation time. We found that, compared to the control, cold priming significantly reduced the number of leaves and plant height to first inflorescence as well as DSA (2.7 d), while K supplementation reduced DAR (8.8 d). No effects of these treatments were observed for other growth of physiological traits. In a third experiment with XL containers in the spring-summer cycle, the combination of cold priming plus K supplementation was tested, confirming the significant effect of the combination on generation time (2.9 d for DSA and 3.9 d for DAR). Embryo rescue during the cell expansion cycle (average of 22.0 d and 23.3 d after anthesis for M82 and Moneymaker, respectively) allowed shortening the generation time by 8.7 d in M82 and 11.6 d in Moneymaker compared to the in planta fruit ripening. The combination of agronomic treatments with embryo rescue can make an effective contribution to increase the number of generations per year for speed breeding in tomato from the current three to four.
Keywords: Solanum lycopersicum, generation time, speed breeding, container size, cold priming, K supplementation, embryo rescue.
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
Dualex植物多酚-叶绿素仪:便携式叶绿素仪测量作物叶片叶绿素浓度的评估
Dualex植物多酚-叶绿素仪:从高光谱图像和SIF反演估算辐射传输Vcmax来评估雨养和灌溉植物表型试验中的光合性能
Dualex植物多酚-叶绿素仪:单金属和双金属植物纳米颗粒对Mezquit生理状态的影响
Dualex植物多酚-叶绿素仪:LED照明剂量对tatsoi光合指标的影响
Dualex植物多酚-叶绿素仪:利用Dualex非破坏性测量确定不同甜樱桃园的覆盖下光有效性™
Dualex植物多酚-叶绿素仪:硅在渗透胁迫下介导两种不同番茄基因型差异耐逆反应中的调节作用
Dualex植物多酚-叶绿素仪:用非破坏性荧光传感器监测两个苹果品种对供水条件的生理生化反应
Dualex植物多酚-叶绿素仪:从Sentinel-2光谱带反演冠层叶绿素含量以估算冬小麦集约种植系统的氮素吸收
Dualex植物多酚-叶绿素仪:胚胎大小作为种子捕食耐受性性状:胚胎受损种子对植株再生的贡献
Dualex植物多酚-叶绿素仪:基于叶片荧光和黄酮含量的马铃薯作物氮素状况评估光学指标的比较
Dualex植物多酚-叶绿素仪:四倍体柑橘砧木提高普通克莱门汀(柑橘克莱门汀)低温胁迫耐受能力
Dualex植物多酚-叶绿素仪:具有高镉适应性的入侵草的叶片功能特性
Dualex植物多酚-叶绿素仪:几种内生细菌对鼠尾草幼苗生长和生理性状的影响
Dualex植物多酚-叶绿素仪:利用多角度遥感校正冠层结构效应估算小麦叶片氮和叶绿素含量
Dualex植物多酚-叶绿素仪:野生矮灌木蓝莓氮素状况的快速诊断
Dualex植物多酚-叶绿素仪:基于无人机的大豆FVC、LCC和成熟度遥感监测
Dualex植物多酚-叶绿素仪:应用形态学和生物化学标记评价两种园林植物的干旱响应
Dualex植物多酚-叶绿素仪:温度、浇水制度和脱落酸对番茄幼苗生长发育的个体和交互生态生理效应
Dualex植物多酚-叶绿素仪:对硬粒小麦灌浆期间光合器官的分析表明,穗是一个耐水胁迫的器官,花序梗是的初级代谢产物库
Dualex植物多酚-叶绿素仪:短日紫外线照射下1-氨基环丙烷-1-羧酸合成酶和氧化酶基因家族在番茄叶片和根中的差异表达Dualex植物多酚-叶绿素仪:水培试验的设计,以评估新型有机和有机矿物产品的生物刺激潜力
基于Dualex氮平衡指数测量仪的作物叶绿素含量估算模型
Dualex植物多酚-叶绿素仪:不同水氮处理对玉米氮素诊断指标的影响
Dualex植物多酚-叶绿素仪:氮肥减量后移对玉米冠层生理性状和产量的影响
