污水处理厂处理技术方案
发表于:2026-2-21 10:49:33|本帖共 2,333 字 673
       污水处理厂的厌氧调节池、曝气池、调节池所产生的废气、臭气主要来自污水、废水本身所含的废气污染物例如苯系物、脂类、酮类、醇类以及污水、废水处理工艺过程所产生的废气及臭气如氮氧化物、硫化氢H2S、氨、二氧化硫SO2、甲烷CH4、硫醇等。
    污水处理厂废气为恶臭气体,极易飘散至周边居民区,引起居民投诉,造成不良影响。因此,需要采取有效的净化治理措施,以确保周边环境、达到国家环保要求。
    废气处理方法:
    1、蓝阳环保天然植物液高效除异味,蓝阳环保污水除臭专用净化设备,采用高效超声波雾化除臭技术,在污水、废水臭气扩散过程中除臭剂溶液形成微小 雾滴将废气分子包围与其紧密附着并吸收去除,其反应基础是泉威环境天然植物液分子与废气分子之间的相近相容原理。该污水除臭方案效率高、费用低、安全无隐 患、无二次污染。
    2、蓝阳环保光催化氧化起能有效去除污水泵站、污水站、废水站、污水厂等场所空气中的恶臭污染物H2S、NH3、CH4、氮氧化物、硫醇以及酮类、醇类、脂类、醚类VOC等有机废气均能够有效降解及控制。
    污水处理厂废气处理应用范围:
    污水处理厂废气处理装置CHO-91GW、蓝阳环保天然植物液广泛用于污水泵站、污水站、废水站的厌氧调节池、曝气池、调节池以及垃圾站、垃圾中转站、垃圾填埋场等各种有臭味的场所。
  Sewage treatment plant anaerobic conditioning tank, aeration tank, adjust the exhaust gas generated by the pool, odor, mainly from sewage, waste water itself contained in the exhaust gas pollutants such as benzene, lipids, ketones, alcohols and water, exhaust gas and waste water treatment process odor generated such as nitrogen oxides, hydrogen sulfide H2S, ammonia, sulfur dioxide, SO2, methane CH4, mercaptan.
  Sewage treatment plant waste gas as malodorous gases, easy to drift to the surrounding residential areas, causing complaints from residents, resulting in adverse effects. Therefore, the need to take effective measures to clean governance, to ensure that the surrounding environment, meet the national environmental protection requirements.
  Exhaust gas treatment methods:
  1, blue-green liquid and efficient natural plant odor, deodorant special blue-green water purification equipment, efficient use deodorant ultrasonic atomization technology, sewage, wastewater odor diffusion process deodorant solution form tiny droplets in the exhaust gas molecules surround and absorb its close attachment removed, the reaction is based on similar principles of compatibility Stephen Granville environment liquid natural plant molecules and gas molecules. The sewage deodorization program high efficiency, low cost, safe and hidden suffering, no secondary pollution.
  2, blue-green photocatalytic oxidation can effectively remove from the sewage pumping station, water stations, waste water stations, sewage plants and other places in the air odor pollutants H2S, NH3, CH4, nitrogen oxides, thiols and ketones, alcohols , lipids, ether VOC and other organic waste degradation and are able to effectively control.
  Sewage treatment plant gas treatment applications:
  Sewage treatment plant gas treatment apparatus CHO-91GW, blue-green liquid natural plant widely used in anaerobic conditioning tank, aeration tank of sewage pumping stations, water stations, water stations, adjust the pool and garbage station, garbage transfer stations, landfill landfill and other smelly places.
感谢分享经验
2026-4-16 05:29:49|本帖共 6 字 回复
2026-6-9 20:36:01|本帖共 4 字 回复
