OmniScan iX UT超声波探伤仪
发表于:2026-5-1 10:10:32|本帖共 983 字 3799
       The OmniScan® iX is an industrial ultrasonic flaw detectorsystem designed for the high-speed testing of critical industrialcomponents. The compact OmniScan iX is housed in a rugged benchtop casing andis also available in a rack-mount version or with a swivel-armassembly for easy integration into a production system.
  The OmniScan iX is central to your industrial component testingsystem. Olympus provides all the software libraries required toenable the integrator to tie in your existing process controlsystem. In addition, we provide the user interface ports necessary toconnect a display, keyboard, mouse, and external storage. Thereal-time programmable alarm and analog outputs, and the encoderoutputs, enable easy integration of the mechanical and electroniccomponents of your industrial process. All that is needed for rapid and efficient component testing isbuilt-in!
  Complete Integrated SolutionAffordable priceRugged construction for industrial environment with rack-mountoptionRemote control functions, for custom programming from PCOptional data library to access A-scan and/or C-Scan on PC, forcustom processing
2026-6-13 04:27:31|本帖共 4 字 回复
好内容值得反复品读和收藏。
2026-9-7 16:03:32|本帖共 13 字 回复
看完楼主的分享,感觉自己又涨知识了!
2026-10-29 19:31:17|本帖共 18 字 回复
