使用Videometer多光谱成像系统无损检测婴儿配方奶粉中的双氰胺
发表于:2026-4-27 09:14:15 3244
       摘要
  背景
  牛奶和牛奶产品中的双氰胺(DCD)污染日益成为紧迫以及广受关注的议题,尤其在发了多起严重食品有效事故后。该研究使用了多光谱成像法(405–970 nm) (Videometerlab多光谱成像仪)联合化学计量法检测婴儿配方奶粉中的双氰胺DCD的方法。偏较小二乘法(PLS),较小二乘支持向量机(LS-SVM)以及BP神经网络(BPNN)用来开发定量模型。
  结果
  与PLS和 LS-SVM法相比,BPNN显著的提升了预测性能,预测测定系数分别= 0.935 和 0.873,1段和2段婴儿配方奶粉剩余预测偏差分别为(RPD) = 3.777和3.060 。另外,多光谱成像可区分纯婴儿配方奶粉和掺有0.01% DCD 双氰胺的奶粉,使用BPNN模型,区分无误。
  结论
  研究显示,多光谱成像结合化学计量法可实现在婴儿配方奶粉中的DCD双氰胺快速无损检测。
  Non-destructive detection of dicyandiamide in infant formula powder using multi-spectral imaging coupled with chemometrics
  Abstract
  BACKGROUND
  Dicyandiamide (DCD) contamination of milk and milk products has become an urgent and broadly recognised topic as a result of several food safety scares. This study investigated the potential of using multi-spectral imaging (405–970 nm) coupled with chemometrics for detection of DCD in infant formula powder. Partial least squares (PLS), least squares-support vector machines (LS-SVM), and back-propagation neural network (BPNN) were applied to develop quantitative models.
  RESULTS
  Compared with PLS and LS-SVM, BPNN considerably improved the prediction performance with coefficient of determination in prediction () = 0.935 and 0.873, residual predictive deviation (RPD) = 3.777 and 3.060 for brand 1 and brand 2 of infant formula powders, respectively. Besides, multi-spectral imaging was able to differentiate unadulterated infant formula powder from samples containing 0.01% DCD with no misclassification using BPNN model.
  CONCLUSION
  The study demonstrated that multi-spectral imaging combined with chemometrics enables rapid and non-destructive detection of DCD in infant formula powder.
