螺杆泵的材料有哪些
发表于:2026-1-3 11:14:14 2970
       螺杆泵的材料有哪些 螺杆泵的材料有哪些 What are the screw material 螺杆泵转子由于工况恶劣,因此选材比空压机、制冷机的螺杆要好,如选用38CrMoAl、40Cr、20Cr13、16Mn、CrS5的、常需经渗氮硬化(HRc56-65)。也有选用CrNi、CrMo、CrNiMo不锈钢、MnCrS钢等 Screw pump rotor due to poor working conditions, so selection than the air compressor, screw chiller is better, such as the selection of 38CrMoAl, 40Cr, 20Cr13, 16Mn, CrS5, and often subject to nitriding, hardening (HRc56-65). Have also selected CrNi, CrMo, CrNiMo stainless steel, MnCrS steel
评论列表(6)
专业分享,值得收藏
2026-1-5 06:01:45 回复
感谢楼主分享技术
2026-1-6 00:43:54 回复
干货满满,谢谢
2026-1-11 01:56:24 回复
2026-5-12 03:22:10 回复
很到位
2026-6-2 16:49:02 回复
点赞
2026-6-9 19:42:11 回复
