Plant Growth Compound Preparation- Indole Butyric Acid · Naphthylacetic Acid mixture
发表于:1 小时前|本帖共 2,523 字 1770
  【1】Product Name Rooted, Lifagen, kuaishenggen
  【2】Preparation 2% Indbutyl·Naphthylacetic Acid soluble powder (1% Naphthylacetic Acid + 1% indole butyric acid), 1.05% Indbutyl·Naphthylacetic Acid aqueous solution (0.2% Naphthylacetic Acid + 0.85% indole butyric acid), 50% Indbutyl·Naphthylacetic Acid soluble powder (10% Naphthylacetic Acid + 40% indole butyric acid), 10% Indbutyl·Naphthylacetic Acid wettable powder (2% Naphthylacetic Acid + 8% indole butyric acid), 0.075% indbutyl · naphthylacetic acid wettable powder (0.025% naphthylacetic acid + 0.05% indole butyric acid)
  【3】Toxicity low toxicity
  【4】Registered crops rice, cucumber, poplar, corn
  Rice
  Seeds were soaked with 28.6~40mg / L (1:1) solution for 10~12h; Spray with 15-20mg/L (NAA: IBA = 1:4) solution once each at 1 leaf and 1 heart stage and 3 leaf and 1 heart stage of rice can promote the differentiation of root primordia of crops, accelerate the growth and development of roots, promote rapid rejuvenation after transplanting, significantly improve the survival rate of transplanting, strengthen plants and increase yield.
  Cucumber
  After the survival of cucumber transplanting (3~4 leaf stage) and at the beginning of flower stage, the treatment of leaf spray with panpan industry's 1.05% Indbutyl·Naphthylacetic Acid diluted 4000~6000 times can induce the formation of adventitious roots, promote the survival rate of transplanting, increase the fruit setting rate in the later stage and prevent fruit falling.
  Poplar
  After binding the branches, soak them in 100~200mg/L (naphthylacetic acid: indole butyric acid = 1:1) solution for 8~12h, and the immersion depth is 2~3cm from the base of the cuttings. After immersion, take out the cuttings; The application of 3.75~5.625 (naphthylacetic acid: indole butyric acid = 1:2) effective components per plant can promote root differentiation, induce the production of adventitious roots, accelerate root growth and development, greatly increase the number and length of fibrous roots, help to form a large and strong root group of plants, and promote the growth and development of plants.
  Corn
  Soaking seeds with 15~20mg / L (naphthylacetic acid: indole butyric acid = 1:4) solution for 5~8h before sowing can stimulate the activity of plant cells, break the dormancy of seeds, promote cell division and expansion, promote root development, and improve the stress resistance of plants.
  【6】Precautions
  ①This product cannot be stored with extremely acidic substances for a long time. It needs to be prepared and used now.
  ②It should be used in accordance with the prescribed dosage and not in excess of the concentration.
  ③Spraying should be done on cloudy days or windless days in the morning and evening. If there is rain within 6h after spraying, supplementary spraying is required.
  If you have any interests about it, pls contact us freely. Then latest price will be shared with you accordingly.
