人(Human)3-羧基-4-甲基-5-丙基-2-呋喃丙酸(CMPF) ELISA检测试剂盒
发表于:半小时前|本帖共 4,424 字 4216
       This CMPF ELISA kit is intended Laboratory for Research use only and is not for use in diagnostic or therapeutic procedures. The S Solution changes the color from blue to yellow and the intensity of the color is measured at 450 nm using a spectrophotometer. In order to measure the concentration of CMPF in the sample, this CMPF ELISA Kit includes a set of calibration standards. The calibration standards are assayed at the same time as the samples and allow the operator to produce a standard curve of Optical Density versus CMPF concentration. The concentration of CMPF in the samples is then determined by comparing the O.D. of the samples to the standard curve.
  Sample collection and storages
  Serum - Use a serum separator tube and allow samples to clot for 30 minutes before centrifugation for 10 minutes at approximately 3000×g. Remove serum and assay immediately or aliquot and store samples at -20℃ or -80℃.Avoid repeated freeze-thaw cycles
  Plasma - Collect plasma using EDTA or heparin as an anticoagulant. Centrifuge samples for 30 minutes at 3000×g at 2-8℃ within 30 minutes of collection. Store samples at -20℃or -80℃. Avoid repeated freeze-thaw cycles.
  Cell culture supernates and other biological fluids - Remove particulates by centrifugation and assay immediately or aliquot and store samples at -20℃or -80℃. Avoid repeated freeze-thaw cycles.
  Note: The samples shoule be centrifugated dequately and no hemolysis or granule was allowed.
  Materials required but not supplied
  1. Standard microplate reader(450nm)
  2. Precision pipettes and Disposable pipette tips.
  3. 37 ℃ incubator
  Precautions
  1. Do not substitute reagents from one kit to another. Standard, conjugate and microplates are matched for optimal performance. Use only the reagents supplied by manufacturer.
  2. Do not remove microplate from the storage bag until needed. Unused strips should be stored at 2-8°C in their pouch with the desiccant provided.
  3. Mix all reagents before using.
  Remove all kit reagents from refrigerator and allow them to reach room temperature ( 20-25°C)
  Materials supplied
  Name
  96 determinations
  48 determinations
  Microelisa stripplate
  12*8strips
  12*4strips
  Standard
  0.3ml*6tubes
  0.3ml*6tubes
  Sample Diluent
  6.0ml
  3.0ml
  HRP-Conjugate reagent
  10.0ml
  5.0ml
  20X Wash solution
  25ml
  15ml
  Chromogen Solution A
  6.0ml
  3.0ml
  Chromogen Solution B
  6.0ml
  3.0ml
  S Solution
  6.0ml
  3.0ml
  Closure plate membrane
  2
  2
  User manual
  1
  1
  Sealed bags
  1
  1
  Note: Standard (S0 → S5) concentration was followed by:0,7.5,15,30,60,120 pg/ml.
  Reagent preparation
  20×wash solution:Dilute with Distilled or deionized water 1:20.
  Assay procedure
  1. Prepare all reagents before starting assay procedure. It is recommended that all Standards and Samples be added in duplicate to the Microelisa Stripplate.
  2. Add standard: Set Standard wells, testing sample wells. Add standard 50μl to standard well.
  3. Add Sample: Add testing sample 10μl then add Sample Diluent 40μl to testing sample well; Blank well doesn’t add anyting.
  4. Add 100μl of HRP-conjugate reagent to each well, cover with an adhesive strip and incubate for 60 minutes at 37°C.
  5. Aspirate each well and wash, repeating the process four times for a total of five washes. Wash by filling each well with Wash Solution (400μl) using a squirt bottle, manifold dispenser or autowasher. Complete removal of liquid at each step is essential to good performance. After the last wash, remove any remaining Wash Solution by aspirating or decanting. Invert the plate and blot it against clean paper towels.
  6. Add chromogen solution A 50μl and chromogen solution B 50μl to each well. Gently mix and incubate for 15 minutes at 37°C. Protect from light.
  7. Add 50μl S Solution to each well. The color in the wells should change from blue to yellow. If the color in the wells is green or the color change does not
  appear uniform, gently tap the plate to ensure thorough mixing.
  8. Read the Optical Density (O.D.) at 450 nm using a microtiter plate reader within 15 minutes.
  Calculation of results
  1. This standard curve is used to determine the amount in an unknown sample. The standard curve is generated by plotting the average O.D. (450 nm) obtained for each of the six standard concentrations on the vertical (Y) axis versus the corresponding concentration on the horizontal (X) axis.
  2. First, calculate the mean O.D. value for each standard and sample. All O.D. values, are subtracted by the mean value of the zero standard before result interpretation. Construct the standard curve using graph paper or statistical software.
  3. To determine the amount in each sample, first locate the O.D. value on the Y-axis and extend a horizontal line to the standard curve. At the point of intersection, draw a vertical line to the X-axis and read the corresponding concentration.
  4. Any variation in operator, pipetting and washing technique, incubation time or temperature, and kit age can cause variation in result. Each user should obtain their own standard curve.
  5. The sensitivity by this assay is 1.0 pg/ml
  6. Standard curve
  Storage: 2-8℃.
  validity: six months.
  原创作者:上海瑞番生物科技有限公司
