Spider mites are the most important pests of many crops, and they are difficult to prevent and treat. As we all know, spider mites have two outbreak periods a year: March-May and September-October. Especially after entering April, the population of red spiders expands rapidly under the nourishment of suitable temperature and abundant young branches and leaves. How should we prevent and control it?
Red spiders generally form two damage peaks in March-May and September-October.At this time, it is necessary to use acaricide reasonably
The use of copper preparations and nitrogen-containing foliar fertilizers has also accelerated the outbreak of red spiders. Repeated use of copper preparations can easily induce red spiders to lay eggs. Foliar fertilizers can make fruit tree leaves have sufficient nutrition and provide sufficient food for red spiders.
1. Reasonable and gradual mixing
It is generally recommended to use compound dosage forms, such as Avi etoxazole, Avi spirofen, etc., or several single agents can be mixed. For example, etoxazole alone is not enough, then we can use etoxazole at the same time Add abamectin. If you are still not satisfied, you can use etoxazole + abamectin together with the insecticide profenofos, the effect of killing mites will be better, and it will treat both insects and mites.
It is not enough to use spirulina alone, so we can add avermectin while using spirulina. If you are still not satisfied, you can use the insecticide triazophos at the same time as spirodiclofen + abamectin, and the acaricidal effect will be better.
In addition, it can be compatible with the fungicide mancozeb at the same time to treat insect and mite diseases. It should be noted that such a large prescription is more likely to cause phytotoxicity, so it is necessary to choose high-quality pesticides and avoid using them in the young fruit stage as much as possible.
2. Seize the critical moment of prevention and control
The occurrence of red spider mites is related to temperature. Under normal management, there will be two high-incidence periods a year. When the high-incidence period is about to begin, it will be more effective to use long-acting acaricides for key control.
It can also be re-protected at the end of May and the beginning of June when the temperature turns high and the population of spider mites declines. Then in the high temperature season, only the insecticide carbosulfan or the fungicide mancozeb can be used to control other pests, so that the entire control The cost will be greatly reduced.
3. Emphasis on return carbine tactics
The effect of conventional control is not ideal. If the spider mites break out, you can use the carbine tactic: first apply a quick-acting acaricide against adult mites, and when the efficacy of the drug decreases and the eggs gradually hatch on the 5th day, apply a quick-acting + long-acting acaricide again. To avoid another round of insect damage after the red spider eggs hatch, a relatively ideal control effect can be obtained.
When spraying medicine, there must be enough water and thorough penetration. Red spider eggs are generally produced on the back of leaves and in the grooves of branches, which is not conducive to pesticide coverage, so you must be careful and careful when spraying pesticides, and don't miss or miss spraying.
Zhengzhou Delong Chemical CO., Ltd. is the production base of plant growth regulators in China, which established in 2009, specializing in offering plant protection products. If you have any question, contact us any time.
