多槽手动超声波清洗机是一种常用于工业、医疗、电子等领域的清洗设备,以下是关于它的相关知识:
Multi slot manual ultrasonic cleaning machine is a commonly used cleaning equipment in industrial, medical, electronic and other fields. The following is related knowledge about it:
结构组成
Structural composition
清洗槽:通常由多个不同功能的槽体组成,一般包括超声波清洗槽、漂洗槽、干燥槽等。槽体多采用不锈钢材质,具有耐腐蚀性和良好的超声波传导性能。
Cleaning tank: It is usually composed of multiple tanks with different functions, including ultrasonic cleaning tank, rinsing tank, drying tank, etc. The tank body is mostly made of stainless steel material, which has corrosion resistance and good ultrasonic conductivity.
超声波发生器:为清洗机提供高频电能,驱动换能器产生超声波。它可以调节超声波的频率、功率等参数,以适应不同的清洗需求。
Ultrasonic generator: Provides high-frequency electrical energy to the cleaning machine, driving the transducer to generate ultrasonic waves. It can adjust the frequency, power and other parameters of ultrasonic waves to meet different cleaning needs.
换能器:将电能转换为机械能,产生超声波振动。一般安装在清洗槽底部或侧面,通过将高频电能转换为机械振动,使清洗液中产生大量微小气泡,实现清洗效果。
Transducer: converts electrical energy into mechanical energy and generates ultrasonic vibration. Generally installed at the bottom or side of the cleaning tank, it converts high-frequency electrical energy into mechanical vibration to generate a large number of tiny bubbles in the cleaning solution, achieving the cleaning effect.
加热系统:部分多槽手动超声波清洗机配备加热系统,可对清洗液进行加热。适当的温度能提高清洗剂的活性和清洗效率,通常加热温度可在常温至 80℃左右范围内调节。
Heating system: Some multi slot manual ultrasonic cleaning machines are equipped with a heating system that can heat the cleaning solution. Appropriate temperature can improve the activity and cleaning efficiency of cleaning agents, and the heating temperature can usually be adjusted within the range of room temperature to around 80 ℃.
循环过滤系统:用于过滤清洗液中的杂质和污垢,保持清洗液的清洁度,延长清洗液的使用寿命,同时也有助于提高清洗效果。
Circulating filtration system: used to filter impurities and dirt in cleaning solution, maintain the cleanliness of the cleaning solution, extend the service life of the cleaning solution, and also help improve the cleaning effect.
工作原理
working principle
多槽手动超声波清洗机主要基于超声波的空化效应工作。当超声波发生器产生的高频振荡信号传送给换能器后,换能器将其转换为高频机械振动并传递到清洗液中。在清洗液中,这些高频振动会使液体分子产生疏密变化,形成无数微小的气泡。在气泡形成和闭合的过程中,会产生瞬间的高温、高压和的冲击力,这些力量能够将物体表面的污垢、油脂、灰尘等杂质迅速剥落,从而达到清洗的目的。在多槽设计中,不同的槽体可以实现不同的清洗阶段,如粗洗、精洗、漂洗等,以提高清洗质量。
The multi slot manual ultrasonic cleaning machine mainly works based on the cavitation effect of ultrasonic waves. When the high-frequency oscillation signal generated by the ultrasonic generator is transmitted to the transducer, the transducer converts it into high-frequency mechanical vibration and transmits it to the cleaning solution. In the cleaning solution, these high-frequency vibrations will cause changes in the density of liquid molecules, forming countless tiny bubbles. During the formation and closure of bubbles, instantaneous high temperature, high pressure, and strong impact force are generated, which can quickly peel off impurities such as dirt, grease, dust, etc. on the surface of the object, thus achieving the purpose of cleaning. In multi tank design, different tank bodies can achieve different cleaning stages, such as coarse washing, fine washing, rinsing, etc., to improve cleaning quality.
特点
characteristic
清洗效果好:能够深入到物体的细微缝隙和孔洞中,对复杂形状的物体也能进行全面清洗,清洗,可有效去除各类顽固污垢。
Good cleaning effect: It can penetrate into the subtle gaps and holes of objects, and can comprehensively clean complex shaped objects. The cleaning effect is significant and can effectively remove various stubborn dirt.
操作灵活:多槽设计使得用户可以根据不同的清洗需求和工艺,自由组合清洗步骤,手动控制每个槽体的工作状态,如清洗时间、温度、功率等参数。
Flexible operation: The multi slot design allows users to freely combine cleaning steps according to different cleaning needs and processes, and manually control the working status of each slot body, such as cleaning time, temperature, power and other parameters.
适用性强:可适用于多种材质和类型的物品清洗,如金属、玻璃、塑料、陶瓷等,广泛应用于电子、机械、医疗、珠宝、光学等多个行业。
Strong applicability: Suitable for cleaning various materials and types of items, such as metal, glass, plastic, ceramics, etc., widely used in multiple industries such as electronics, machinery, medical, jewelry, optics, etc.
成本较低:相对于一些自动化程度较高的清洗设备,多槽手动超声波清洗机的价格较为亲民,且维护成本相对较低,适合中小企业或对清洗量要求不是特别大的用户使用。
Low cost: Compared to some highly automated cleaning equipment, multi slot manual ultrasonic cleaning machines are more affordable and have relatively low maintenance costs, making them suitable for small and medium-sized enterprises or users who do not have particularly large cleaning volume requirements.
操作注意事项
Operation precautions
正确安装和连接:在使用前,要确保清洗机各部件安装牢固,超声波发生器与换能器之间的连接正确无误,电源供应稳定且符合设备要求。
Proper installation and connection: Before use, ensure that all components of the cleaning machine are securely installed, the connection between the ultrasonic generator and transducer is correct, the power supply is stable and meets the equipment requirements.
选择合适的清洗液:根据被清洗物品的材质和污垢类型,选择合适的清洗液。避免使用对清洗槽或被清洗物品有腐蚀性的清洗液,同时要注意清洗液的浓度和配比,以达到清洗效果。
Choose the appropriate cleaning solution: Select the appropriate cleaning solution based on the material and type of dirt of the item being cleaned. Avoid using cleaning solutions that are corrosive to the cleaning tank or the items being cleaned, and pay attention to the concentration and ratio of the cleaning solution to achieve the best cleaning effect.
控制清洗参数:根据清洗对象和清洗要求,合理设置超声波的功率、频率、清洗时间和温度等参数。一般来说,功率越大、清洗时间越长,清洗效果越好,但也要考虑到被清洗物品的耐受程度,避免因参数设置不当而损坏物品。
Control cleaning parameters: Set the power, frequency, cleaning time, and temperature of ultrasonic waves reasonably according to the cleaning object and requirements. Generally speaking, the higher the power and the longer the cleaning time, the better the cleaning effect. However, it is also necessary to consider the tolerance of the cleaned items and avoid damaging them due to improper parameter settings.
安全操作:在清洗机运行过程中,不要将手或其他身体部位直接放入清洗槽内,以免受到超声波和清洗液的伤害。同时,要定期检查设备的电气系统和接地情况,确保操作安全。
Safe operation: During the operation of the cleaning machine, do not put your hands or other body parts directly into the cleaning tank to avoid injury from ultrasonic waves and cleaning solution. At the same time, it is necessary to regularly inspect the electrical system and grounding of the equipment to ensure safe operation.
维护保养
Maintenance and upkeep
定期清洁槽体:清洗完成后,及时清理清洗槽内的污垢和杂质,防止污垢堆积影响清洗效果和设备性能。可使用软布和温和的清洁剂对槽体进行擦拭,避免使用尖锐工具刮伤槽体表面。
Regularly clean the tank body: After cleaning, promptly clean the dirt and impurities in the cleaning tank to prevent the accumulation of dirt from affecting the cleaning effect and equipment performance. Soft cloth and mild cleaning agent can be used to wipe the groove body, avoiding scratching the surface of the groove body with sharp tools.
检查超声波系统:定期检查超声波发生器和换能器的工作状态,查看是否有异常声音、发热等现象。如有故障,应及时联系专业人员进行维修。
Check the ultrasonic system: Regularly inspect the working status of the ultrasonic generator and transducer to see if there are any abnormal sounds, heating, or other phenomena. If there is a malfunction, professional personnel should be contacted promptly for repair.
更换清洗液和过滤器:根据清洗液的使用情况和污染程度,定期更换清洗液。同时,按照设备说明书的要求,定期更换循环过滤系统中的过滤器,以保证清洗液的清洁度。
Replace cleaning solution and filter: Regularly replace the cleaning solution according to its usage and degree of contamination. At the same time, according to the requirements of the equipment manual, regularly replace the filters in the circulating filtration system to ensure the cleanliness of the cleaning solution.
保持设备干燥:在设备不使用时,应保持设备干燥,避免清洗槽内积水,防止发生腐蚀和电气故障。
Keep the equipment dry: When the equipment is not in use, it should be kept dry to avoid water accumulation in the cleaning tank and prevent corrosion and electrical failures.
本文由多槽手动超声波清洗机友情奉献.更多有关的知识请点击: http://www.jnthcsb.com真诚的态度.为您提供为全面的服务.更多有关的知识我们将会陆续向大家奉献.敬请期待.
This article is a friendly contribution from a multi slot manual ultrasonic cleaning machine For more information, please click: http://www.jnthcsb.com Sincere attitude To provide you with comprehensive services We will gradually contribute more relevant knowledge to everyone Coming soon.
