世界那么大,选购玻璃钢脱硫塔来我们河北湖城环保就对了!!
发表于:6 天前|本帖共 1,050 字 2762
       选用液气别离器,由液膜吸附式液气别离原理制作而成的除雾器,能把微小的小液滴从烟气中别离出来,使体系耗水量下降,以节省运转本钱。
  The structure planning is reasonable, and the FRP desulfurization tower manufacturer tells you the precautions for selection. The absorption tower should be equipped with a ventilation fan with the capacity meeting the requirements to ensure excellent ventilation in the absorption tower。
  随着玻璃钢技术的开展,脱硫塔逐步改为用玻璃钢制作。比较花岗岩脱硫塔,玻璃钢脱硫塔本钱低、加工容易、不锈不烂、重量轻,因而成为往后脱硫塔的开展趋势。
  另外不锈钢具有耐腐蚀、耐高温、耐磨损三大优势,也是玻璃钢脱硫塔开展重要趋势之一。那么,现在玻璃钢脱硫塔在技术上有哪些?
  In the absorption tower, reduce the rubber plate and glue used in the rubber lining operation of inflammables. Take as much as you need. Generally, you can control about 5 small barrels without accumulation. Outstanding anti-corrosion function: good resistance to air, water, acid, alkali, salt, oil and solvent. Sodium hydroxide (NaOH) solution is selected as absorption and Neutralization Solution in DGS jet bubbling waste gas purification tower。
  酸雾废气由风机压入净化塔中段内筒构成压力室,再由压力室均配给各根鼓泡管,废气通过鼓泡管进入贮液箱的吸收中和液中产生鼓泡,气泡通过滤料环层,使气液再次得到充沛触摸后,经脱液网脱液,然后排入大气。
  依据以上规划原理,改善了一般玻璃钢净化塔的结构,采取了以下办法:运用旋流技术、射流技术、压力雾化技术和冲击设备技术,使烟气和脱硫液充沛触摸,到达抱负的脱硫作用。腐蚀性的电功能:能够用来制作绝缘体。http://www.huchengboligang.com
