Today, let me introduce the advantages of stainless steel crushers
发表于:3 天前|本帖共 3,323 字 3199
  Universal crusher is a widely used crushing equipment, and its advantages are mainly reflected in the following aspects:
  Wide applicability: It can handle various materials, including dry chemical raw materials, food raw materials, ores, plastics, etc. Whether it is brittle, fibrous or general materials, it can be crushed without frequent equipment replacement.
  Good crushing effect: The crushing particle size can be adjusted according to the needs, which can crush the material to a finer degree, and the crushed material particles are uniform, meeting the requirements of different industries for material fineness.
  Easy to operate: The structure is relatively simple, the operation process is easy to master, and there is no need for complex training to get started in daily use. Maintenance and upkeep are also convenient, and parts replacement and cleaning are relatively easy.
  High efficiency: It can quickly process materials while ensuring the crushing effect, suitable for mass production, and improve work efficiency.
  Compact structure: Small footprint, easy to install and use in limited spaces such as workshops or laboratories, saving space.
  The working principle of a universal crusher is mainly to crush materials through the interaction between high-speed rotating components and fixed components. The specific process is as follows:
  1. Material entry: The material to be crushed enters the crushing chamber through the feeding port.
  2. High speed impact and shearing: The crushing chamber is equipped with a high-speed rotating rotor (usually with blades, hammers, and other components), which generates strong centrifugal and impact forces when the rotor rotates. The material is subjected to strong impact, shear, collision, and friction between the high-speed rotating rotor and the fixed lining plate (or screen).
  3. Refinement and Separation: The material is gradually crushed into small particles under the aforementioned forces. When the particle size is smaller than the aperture of the sieve, it will pass through the sieve under centrifugal force or airflow and be discharged from the discharge port; Particles that do not meet the fineness requirements will continue to be repeatedly crushed in the crushing chamber until they meet the specifications.
  This principle enables the universal crusher to efficiently process materials of various properties, and by adjusting the mesh aperture, the particle size of the crushed material can also be controlled.
  The characteristics of a universal crusher mainly include the following:
  -Widely applicable materials: It can handle various types of materials, whether it is dry Chinese medicinal materials, chemical raw materials, food raw materials, or ores, plastics, etc. As long as the hardness and humidity are within the appropriate range, it can be crushed and has strong versatility.
  -Adjustable crushing particle size: By changing the sieve mesh with different aperture sizes, the particle size of the crushed material can be flexibly controlled to meet the requirements of different scenarios for material fineness.
  -Simple and easy to maintain structure: The overall structure is not complicated, mainly composed of core components such as crushing chamber, rotor, and screen mesh, making daily cleaning, component replacement, and maintenance relatively convenient.
  -High work efficiency: relying on the impact force generated by high-speed rotating components to quickly crush materials, suitable for batch processing, and able to complete crushing operations in a relatively short time.
  -Easy to operate: The operation process is simple and does not require complex professional skills. After simple training, it can be used and the operation process is relatively stable.
  -Compact size: The equipment occupies a small area, saves space, and is easy to install and use in laboratories, small workshops, and other places.
