本页面标准信息均来源于网络收集,或由参与标准制定的供应商提供,只作为参考使用,为确保测试结果的准确性、节省您的时间,如需BS 7479标准详细信息或BS 7479具体测试方法,欢迎与我们技术人员联系或给我们留言,我们将为您相关的技术支持。
BS 7479标准介绍
BS 7479英文简介
Can be used to test the relative resistance to corrosion of metallic materials with or without temporary or permanent corrosion protection, when exposed to a salt spray climate (neutral salt spray or acetic acid salt spray or copper accelerated acetic acid salt spray) at an elevated temperature.
Test specimens are placed in an enclosed chamber and exposed to a continuous indirect spray of neutral (pH 6.5 to 7.2) or acidified (pH3.1 to 3.3) salt water solution, which falls-out on to the specimens at a rate of 1.0 to 2.0ml/80cm²/hour, in a chamber temperature of +35C or +50C. This climate is maintained under constant steady state conditions. The test duration is variable.
This standard has been superseded by ISO 9227.
These tests are also referred to as a NSS, ASS & CASS tests.
For further information on British standards visit; www.bsi。。org.uk
▼BS 7479第三方检测机构
以上标准信息来自互联网搜索整理,如需了解完整的BS 7479的信息或BS 7479标准解读,欢迎详询。 |
