How does the batching system of concrete batching plant equi
发表于:5 天前|本帖共 1,164 字 467
       The concrete plant equipment is generally composed of stirring system, batching system, weighing system, control system, storage system, and so on. The batching system is realized through a concrete batching machine. The structure of the batching machine includes the feeding system, the weighing system and the electrical control system. Each part has the corresponding functions and responsibilities, and the equipment of the concrete batching plant can be completed by the coordinated operation.
The electrical control system is the core part of the batching machine. Its function is to realize the weighing, display, operation and complete various automatic batching procedures for the entire batching machine. The system is mainly composed of a batching controller and a high-power circuit. The feeding system is mainly used for storing materials, and feeding the weighing hopper under the control system operation. The key part of the weighing system is composed of weighing hoppers, suspension devices, weighing system sensors and batching controllers. It is responsible for the accurate measurement of the amount of material needed for each batching. PLD concrete batching machine is the most frequently used type of batching machine currently used in concrete batching plant equipment, and it is characterized by high efficiency, stability, and automation.
