Customization makes the device understand you better
发表于:2026-10-27 12:32:31|本帖共 2,772 字 2766
       In the electrical assembly manufacturing industry, busbar processing machines are indispensable key equipment. Shandong Gaoji is always committed to providing customers with high-quality and high-performance busbar processing machines to meet the diverse needs of different customers.
  Customized CNC busbar bending machine
  The busbar processing machine of Shandong Gaoji is equipped with multiple advanced technologies. It mainly has multiple processing units such as shearing, punching and bending, and can precisely process copper and aluminum busbars of different specifications. For instance, the punching unit adopts a high-precision five-arm punching die base, which not only extends the service life of the die but also makes the operation line of sight clearer and the use more convenient and faster. There is no need to frequently replace the die, and the production efficiency is significantly higher than that of traditional punching units. The bending unit adopts horizontal processing, which is safe and convenient. It can complete U-shaped bends as small as 3.5mm. It also has a hook-type open bending station, which can easily process special circular small bends, embossing, vertical bends, etc. Moreover, multiple workstations of the machine can operate simultaneously without affecting each other, significantly enhancing work efficiency. The working stroke of each processing unit can be conveniently adjusted, reducing auxiliary processing time and further improving production efficiency. The hydraulic oil tank is welded with thick steel plates and has undergone phosphating treatment to ensure that the hydraulic oil will not deteriorate over long-term use. The hydraulic rubber hoses adopt the national standard A-type connection method, which is durable and convenient for maintenance.
  It is worth mentioning that Shandong Gaoji is well aware that the production demands and application scenarios of each customer are different. Therefore, we offer customized services for busbar processing machines. Whether you need to specially customize the functions of the equipment, adjust the external dimensions of the equipment according to the spatial layout of the workshop, or have specific requirements for processing accuracy and production efficiency, the professional team of Shandong Gaoji can communicate with you in depth. With rich experience and advanced technology, we can tailor the most suitable busbar processing machine for you. From the initial demand research and solution design, to the mid-term production and manufacturing, installation and commissioning, and then to the later after-sales service and technical support, we will follow up throughout the process to ensure that your customized equipment can operate efficiently and stably, bringing the greatest value to your production.
  Choosing the custom busbar processing machine from Shandong Gaoji means choosing professionalism, efficiency and thoughtfulness. We look forward to working hand in hand with you to jointly create a new situation in the electrical assembly manufacturing industry. If you have any demands or questions about the busbar processing machine, please feel free to contact us at any time. We will serve you wholeheartedly.
