The public's perception of smog is directly proportional to the sales of air purifiers
The demand is indeed coming up, but the embarrassing thing is that most people don't know how to choose an air purifier? Big brands are too expensive, and cheap and small brands are not easy to trust.
Which air purifier works better?
"HEPA filter"
In fact, the market has made a choice for this problem. At present, the HEPA filter has the best effect in filtering PM2.5 and has become the mainstream option in the market.
HEPA (High Efficiency Particulate Arrestment) is the abbreviation for High Efficiency Particulate Arrestment, and it is also commonly referred to as High Efficiency Particulate Arrestment.
The HEPA filter is based on the HEPA theory, and this theory was created as early as 1942 when the Manhattan Project was implemented in the United States to block nuclear radiation particles.
This kind of filter was mainly used in the aviation industry at first, and later extended to medical, precision manufacturing and household consumer products. Therefore, HEPA filtration is actually not a high-tech, it has been applied decades ago.
When choosing an air purifier, you can choose without thinking when you see the HPEA filter. However, here comes the problem again!
The purification ability mainly depends on the following three indicators
①The noise level
Understand the noise decibels produced by the air purifier in different working modes. During the trial process, the sound from the machine can be compared to the following scenes. Generally speaking, if the sound is below 40dB(A), it has no effect on the human body; if the person continues to be in a space where the sound is 40dB(A) to 60dB(A), the nervous system will be affected; on this basis When the noise increases by 3dB(A) on average, the noise energy will be doubled; when the sound reaches 65dB(A) to 80dB(A), the degree of human cardiovascular damage is 50dB(A) than living in noise People in the environment are more than 20% higher.
It must be lower than 35dB(A) at night. The lower the upper limit, the quieter it is. Most products are in the range of 45dB(A) to 65dB(A). Choose according to your needs.
②Cleaning capacity CADR
CADR is the abbreviation of Clean Air Delivery Rate, translated as Air Clean Rate, which is an international standard specifically used to measure the overall performance of air purifiers.
Specifically, the CADR value represents the volume of air that can be purified per unit time, which is also the internationally authoritative data for measuring the air purification capacity of purifier products. The higher the CADR value, the higher the purification efficiency of the purifier, and if it is lower than 300, you should not consider it.
③Cleaning cost CCM
CCM is the abbreviation of Cumulate Clean Mass. The cumulative purification amount is further divided into "particulate matter cumulative purification" and "gaseous pollutant (formaldehyde) cumulative purification amount". Here, the purification cost is mainly discussed from the smog (particulate matter).
This value is directly related to the length of time that the filter element can work. The higher the value, the longer the service life. At the same time, the service life of the air purifier filter is also affected by other factors such as air volume and duct design. CCM can only be used as a reference value. .
The particulate matter CCM is represented by P and is divided into four levels. From low to high, they are P1, P2, P3, and P4. The total weight of the corresponding purified particulate matter is 3000-5000mg, 5000-8000mg, 8000-12000mg, 12000mg or more. The advanced level is P4.
