What are the production conditions of snack food machine
Leisure food is mainly based on less water rice, wheat, beans as raw materials, after heating and pressure treatment, so that its volume expansion, structure changes, and through a special mold hole to get a variety of shapes, and then processed into convenient food. This kind of food structure bulky, crisp texture, easy to use, rich nutrition, easy to digest, especially suitable for the elderly and children to eat, but also People's Daily ideal snack food. When using snack food machine to produce snack food, it is usually completed in the form of snack food production line through multiple procedures. What are the main machines in snack food production line? 1. Pre-processing equipment. The horizontal powder mixer, mixer and other machinery will be used to fully mix all kinds of materials according to different proportions, and the screw conveyor will be used to evenly send the materials into the screw barrel of the snack food machine. The feeding capacity range of the feeder is 0-320kg/h, which can be infinitely variable speed.
2. Snack food machine cutting equipment. The production of direct snack food tanker, the selection of single screw extruder. During production, the screw speed is 220-350rpm, the temperature is 120-160℃, and the maximum pressure in the extruder is 0.8-1MPa. The stay time in the snack food machine is 10-20s. Twin screw extruder can also be used, and the screw speed can be variable in 0-220rpm. Extrusion type bulking equipment is a very efficient converter to convert electrical energy into heat energy. Its main functions are to mix, heat, cut, shape and expand raw materials. After passing through the mold, the volume of food expands rapidly due to the rapid escape of water vapor. According to the different requirements of the length of food can be used to cut off its own cutter, can also use the cutting machine in the auxiliary machine to cut off, generally more than 4mm of food need to cut off the cutting machine. Adjust the speed of the cutter to achieve different sticking length.
3. Filling extrusion and filling device. Including filling insulation melting cylinder, screw pump, filling extruder. The die head of snack food machine is a composite die, which is mainly composed of nozzle plate, tube mold and filling tube. There are two thin tubes in the die head respectively to the axis of the screw shaft. When the extrusion material passes through the gap between the thin tube and the die head, the filling material is injected into the thin tube at the same time. When the material leaves the outer end of the die head, due to the sudden drop of pressure, the volume of the material expands rapidly to form a bulky shell and the packing is wrapped tightly.
4.Baking equipment. In the snack food machine production process, the commonly used baking equipment is electric oven, gas oven, microwave, etc., the moisture of baked food is 3%-6%. When the relative humidity in the air is large, the puffed product can also be cooled out of part of the water by the conveyor belt.
5. Flavoring system device. Including two flavoring cans, flavoring spray pump, continuous flavoring machine, powder spraying device, flavoring system can be snack food into a variety of flavors of snacks. 6. Packing machine. Nitrogen filling metering packaging machine is generally adopted.
7. If the surface of the product needs to be coated with chocolate skin, a dip coating machine and cooling device should be added.
Snack food in all parts of the world have a certain market, such as Cheerios, Cheese Circle, Ping-Pong, etc., also began to rise, by the people next to the welcome. snack food machine, because of its production equipment investment is less, the production operation is relatively simple, the production variety is diversified, has better investment economic benefits and economic benefits. Jinan FLD Machinery Co., Ltd. Welcome all major customers to consult and order. Contact: Kevin, Tel :86-. Our company will wholeheartedly provide you with better prices and more reasonable product solutions.
