Fire Retardant Synthetic Leather | Custom FR Faux Leather | DERFLEX
发表于:2026-10-21 11:23:33|本帖共 8,562 字 2890
       Synthetic leather developed around the fire-safety requirement of the final product—not a generic “FR” label. DERFLEX supports PU, PVC and application-oriented synthetic leather programs for contract seating, automotive interiors, hospitality furniture and other projects where ignition behavior must be defined and verified.
  Color, grain, backing, thickness, hand feel, abrasion direction, cleanability and the required flame test pathway can be discussed together before sampling. Final compliance depends on the exact material construction, test method and, for some standards, the complete upholstery composite.
  Fire retardant synthetic leather is artificial leather engineered to resist ignition or slow flame spread under a defined test method. It is not “fireproof.” For procurement, the important questions are: which standard, which ignition source, which material structure, and whether the test applies to the leather alone or the complete upholstered composite.
  Fire retardant synthetic leather—also searched as flame retardant synthetic leather, FR faux leather, flame resistant artificial leather or fire retardant PU leather—is a coated or laminated leather-look material whose construction is selected to meet a defined ignition-resistance requirement.
  The material may use a PU, PVC, microfiber or other engineered surface system over a woven, knitted, nonwoven or microfiber substrate. The fire-safety pathway can involve the surface resin, backing, adhesive, intermediate layers or a combination of these elements. Because the chemistry and construction affect hand feel, flexibility, abrasion behavior and processing, FR performance should be planned together with the final application rather than added as an afterthought.
  Defines gloss, touch, stain behavior, cleaning route, color appearance and surface protection.
  PU, PVC or application-specific resin system can be embossed or finished for the required grain and tactile profile.
  Adhesive and intermediate construction influence flexibility, adhesion, conversion behavior and the selected flame-retardant pathway.
  Woven, knitted, nonwoven or microfiber backing is matched to sewing, upholstering, wrapping, stretching and end-use conditions.
  A professional quotation should name the required standard instead of using “FR” as a standalone specification. The examples below are commonly referenced in upholstery and vehicle projects; the applicable version, sample construction and pass criteria must be confirmed for the destination market.
  Often specified for upholstered seating in commercial environments. Requirements can range from ignition sources 0/1 to higher-hazard crib tests. Some evaluations involve a cover-and-filling composite rather than the cover material alone.
  Used to assess ignitability of upholstered furniture by smouldering cigarette and match-flame equivalent ignition sources. Foam and upholstery construction can affect the result.
  Frequently referenced for upholstered furniture and cover fabrics. Compliance terminology should be kept separate from assumptions about whether added flame-retardant chemicals are present.
  Commonly referenced for the flammability of materials used in vehicle occupant compartments. The exact automotive construction, thickness and production route should be represented by the test sample.
  For marine, rail, aviation or country-specific public-space projects, send the customer specification or standard number with the inquiry. DERFLEX can review the material pathway, while final acceptance remains subject to the relevant laboratory test and project authority.
  For safety-related upholstery, buyers reduce risk by checking whether the evidence really matches the material they plan to purchase. This is especially important when color, backing, thickness, foam, lamination or formulation changes between sampling and bulk production.
  A synthetic leather can look identical while using a different backing, coating weight, additive package or adhesive system. Those changes can alter not only flame behavior but also seam strength, hand feel, cold flexibility, abrasion performance and aging.
  DERFLEX therefore treats a fire-retardant program as a controlled material specification: define application → choose construction → make sample → confirm processing → test the representative material or composite → lock the approved specification for production.
  This workflow is designed for importers, furniture factories, automotive interior suppliers, contract upholsterers and private-label brands that need repeatable purchasing rather than a one-time sample.
  DERFLEX can discuss leather grain, color, backing, softness, gloss and performance direction as one integrated specification. Images below are actual DERFLEX synthetic leather materials; fire performance must be confirmed for the selected construction and requested test.
  Suitable for projects that prioritize a softer hand, refined grain and flexible upholstery or wrapping behavior.
  A practical route for projects balancing cleanability, surface durability, water-resistance direction and flame-performance requirements.
  A fire-retardant surface that cannot survive real upholstery production is not a useful specification. DERFLEX can develop the FR pathway alongside the mechanical and visual requirements of the finished product.
  For high-use seating, test level and surface finish should be selected around expected traffic, cleaning frequency and contact wear.
  PU systems for humid or demanding interiors may need a defined hydrolysis-resistance route. The target should be stated before formulation and sampling.
  Hospitality, healthcare and public seating programs may require controlled wipe-clean behavior. Approved cleaners should be tested on the selected top finish.
  Sample-card appearance must translate into bulk rolls. Color targets, embossing and gloss direction can be documented for repeat orders.
  Backing, stretch, thickness and tear direction affect cutting, stitching, quilting, edge wrapping and fitting over foam.
  If a project requires a specific chemical restriction, low-emission route or flame-retardant-additive policy, send the requirement before development so feasibility can be reviewed.
  The values below are quotation and development options rather than fixed universal specifications. Final construction depends on end use, required test method, MOQ, color, backing and destination-market requirements.
  The most suitable resin system and test pathway depend on how the finished product is used, cleaned, installed and regulated.
  A controlled development sequence helps avoid the common failure of approving a beautiful sample first and asking about fire testing only after the product is already engineered.
  DERFLEX supports global B2B buyers that need synthetic leather as a repeatable manufacturing input. The focus is on matching surface design, backing, processing behavior, project performance and bulk supply in one controlled program.
  Commercial buyers often need more than one FR leather SKU. A collection may include several colors, grains or backings while still requiring a consistent appearance and documented compliance route.
  DERFLEX can discuss sample-card development, color families, roll labeling, packing marks and repeat-order controls so that the material works as part of a product program, not only as an isolated swatch.
  Use these related pages to compare base materials, applications and sourcing options. These six internal links are intentionally relevant to the same buyer journey.
  No. Fire retardant synthetic leather is designed to resist ignition or reduce flame spread under a defined test method. It should not be described as fireproof or non-combustible unless a specific, applicable standard proves that claim for the final product.
  They represent different ignition severities and test arrangements for upholstered seating. Source 0/1 is commonly associated with cigarette/match-type ignition, while Crib 5 uses a more severe wooden-crib ignition source. The required level depends on the project and market; the upholstery composite may need to be tested as a system.
  PU synthetic leather can be developed toward a flame-retardant test requirement through its resin, backing, adhesive and overall construction. The final result must be verified using the required test method on a representative sample.
  No. The polymer can have favorable flame behavior, but the finished synthetic leather includes backing, plasticizers, finishes, adhesives and other components. Compliance should be based on the tested product construction, not the resin name alone.
  Not necessarily. Changes in formulation, backing, thickness, coating weight or other construction details can affect relevance. Buyers should confirm that the test evidence applies to the exact product family and production specification they plan to purchase.
  DERFLEX can review projects that require Crib 5, FMVSS 302 or other named fire-test pathways. Feasibility depends on the requested material system and end-use construction. The requirement should be provided before sample development, and final compliance must be confirmed by appropriate testing.
  Send the final application, destination market, required fire standard, color/grain target, backing, thickness or weight direction, roll width, processing method, quantity, packaging requirement and sample deadline. If you have a customer specification or test document, attach it.
  Send DERFLEX your application, required standard, surface target and order details. We can review a suitable synthetic leather development path and prepare the next sampling step.
  Compliance note: Test standards, regulatory requirements and restricted-substance rules vary by country, application and product construction. Product suitability should be confirmed through representative sampling, testing and the buyer's final-product compliance review.
