Shipment Update: 2PCS Replacement Rexroth Gearboxes GFT110W3B115-21T Planetary Reducers For XR250 & XR280 Rotary Drilling Rigs
发表于:2026-10-15 12:58:49|本帖共 2,119 字 2212
       June 16, 2026 | Ningbo, China - PHPFluid completed shipment of 2pcs replacement Rexroth GFT110W3B115-21T planetary gearboxes, compatible with XR250 & XR280 rotary drilling rig main winch systems. The Replacement Rexroth gearboxes are ideal for mobile hydrostatic applications such as propelling drives in tracked vehicles, wheel drives in wheeled vehicles, swing drives for rotary motion, and winch drives for heavy lifting and lowering. Rexroth planetary gearboxes are at work in many industries worldwide, including agriculture, construction and mining.
  Quality & Manufacturing PHPFluid complete range of gearboxes with multiple planetary staging, plus planetary gearboxes that can be combined with numerous replacement Rexroth hydraulic motors – and in some cases, with electric motors. As a fully interchangeable aftermarket solution for original Rexroth winch drives, this GFT110W3B115-21T reducer strictly replicates OEM installation dimensions, torque parameters and heavy-load performance standards. Manufactured with high-strength alloy steel gears and precision machining, it features outstanding wear resistance, stable high-torque output and strong anti-impact capability, perfectly adapting to harsh foundation piling and engineering construction working conditions. It effectively solves the problems of high cost and long delivery cycle of original imported parts, helping customers reduce equipment maintenance costs and improve construction efficiency. Before shipment, every gearbox passed a full set of factory quality inspections, including pressure testing, no-load running test and load performance verification, to guarantee consistent performance equivalent to OEM Rexroth parts.
  Delivery & Packaging Shipped in export-grade wooden cases to ensure safe transit. With PHPFluid's strategic location in Ningbo (a major port city), orders are processed quickly for global delivery-reducing lead times compared to original OEM parts.
  About PHPFluid Ningbo PHP Hydraulics Co., Ltd. (PHPFluid) has been a professional manufacturer of replacement hydraulic pumps, motors, and parts since 2007, serving customers worldwide in construction, mining, marine, and industrial hydraulics. The company specializes in interchangeable components for Danfoss, Rexroth, Vickers, Kawasaki, Caterpillar, Volvo, and other major brands.
  Contact us for detailed product parameters, customized solutions and bulk order quotations.
