Design scheme of frequency air oxidation switching power supply. Because the output waveform is a waveform, it is beneficial to improve the sealing quality, reduce the melting of the film caused by the temperature rise, prevent the expansion of the pores of the air oxide film, improve the strength and relative density of the air oxide layer, improve product quality, and improve product quality. out rate. What are the characteristics of high-frequency air oxidation switching power supply to complete high-current output? 1. Voltage stability, stable current and other controls. 2. Full digital display of current, voltage, working time, frequency meter (optional), component instrument (optional), etc. with high precision and sound and light alarm. 3. Soft start and stop function, with automatic maintenance functions such as overcurrent, overvoltage, undervoltage, overheating, short circuit, etc., with high reliability. 4. Strict tests and long-term aging tests have been carried out on the equipment before leaving the factory. It operates continuously day and night, with an average trouble-free running time (≥) of 50,000 hours. The failure rate is extremely low, and it is true, reliable and durable. 5. Carry out anti-corrosion treatment on the whole machine, seal the control unit, select the sealed B-type anti-corrosion head, and process the sealant of each delivery joint to avoid the corrosion of acid, alkali and salt gas, and ensure long-term stable operation in the corrosive environment . 6. The fully imported pvc shell or spray-painted metal shell is beautiful and will not corrode. It has a direct air-cooled structure and is very convenient for equipment maintenance.
