Detailed configuration and investment profit analysis of Zhengzhou Jianxin HZS90 concrete mixing plant
发表于:2026-9-25 13:46:59|本帖共 1,820 字 4054
       According to the sales data report provided by Jianxin Machinery Sales Department, the most consulted and purchased model of plant is the HZS90 concrete mixing plant. This type of mixing plant is medium-sized and the investment funds are relatively small. Now, I will analyze the configuration and investment profit of HZS90 concrete mixing plant in detail, and give a reference to customers who need to purchase the equipment.
The mixing machine of HZS90 concrete mixing plant adopts JS1500 double-shaft forced concrete mixer. The batching machine is PLD2400 batching machine. The nominal capacity of the concrete mixer machine is 1500 liters. The number and power of mixing motor is 2x30KW. The number and capacity of batching machine are generally 3x100t. The aggregate feeding is fed by a belt conveyor, and the powder is conveyed by screw conveyor. The height of the mixing plant is 4.1m. HZS90 concrete mixing plant has high productivity, and it can guarantee the quality of concrete and save cement. It is often used in large and medium-sized water conservancy, electric power, bridges and other projects with large concrete construction, long construction period and concentrated construction sites. HZS90 concrete mixing plant can mix 90 square meters of concrete per hour and work eight hours a day. Supposing it install 300 days of engineering mixing time per year, the annual concrete output of 90 mixing plants is about 210,000 cubic meters. As for the profit of 90 mixing plants, it is mainly subject to regional restrictions. In general, the net profit per cubic meter of concrete varies from 50-80 yuan RMB. Take 50 yuan for example, the total profit one year is about 10 million RMB. The floor space is generally not less than 4000m2 to meets the construction needs (excluding living area and laboratory). HZS90 concrete mixing plant is a new concrete mixing plant equipment developed by Zhengzhou Jianxin Machinery by using advanced foreign imported mixing technology. The mixing plant has advanced manufacturing technology, reliable quality and high cost performance. It is the top model for investment in small and medium concrete mixing plants.
