Chain condition of the inverter
What is the chain condition of the inverter:
There is certainly no chain reaction when the inverter is standing standby. Only when the inverter is running can there be a chain reaction. The output voltage of the inverter is between the frequency of the frequency of the inverter and the output voltage. Between the motor speed, there is a chain relationship between the inverter output and the output frequency of the inverter, and there is a chain relationship between the output frequency of the inverter and the multi -function relay. There are many such chain relationships.
The inverter chain reaction must be available:
Start the running signal
Frequency given signal
Frequency given channel selection
The inverter closed -loop control also requires simulation feedback
Parameter settings related to multi -function relay chain output
Summarize:
There are still a lot of inverter chain conditions. For specific chain requirements, the inverter must set related parameters. |
